Hoover 3203 Keymatic Video
The Video
AL
thanks for that I remember a very short vid of this on Jacks site on youtube and being frustrated by how short it was.
Depsite my attempts last weekend i still havent managed to get a complete video of it (there was so much going on)
Paul
excellent history lesson there :-)
Keymatics
There is something magical (to me) about these machines i cannot tell you what that is, but when ever that keyplate goes in and you hear the programmer clicking and whirring it is music to my ears.
Gary
Spin Video
Right i have managed to join a few bits of the final spin on the 3203
I am uploading this now and should take about 15 minutes (time 19.03 UK)
Special Machines
Hello Mike
Yes indeed very special machines
I was thinking about the weights and the wide body........maybe by widening the foot print of the machine (widebody) this helps keep things under control when the machine kicks into spin, because if it is not balanced when starting a spin, with the initial violent movement of the tub, the wide footprint helps contain the movement of the body of the machine until the suspension and damper units can take over...........argh my brain hurts now having thought that one through.
It is an amzing peice of engineering inside......the cast cradle for the bearings and motor and the tub design make me think of german machines, the later designs with tub springs on the bottom and cast rear plate must have been a radical design change at the time.
oh blah blah blah LOL :-)
anyway
are you fully recovered now?
is November still on?
Gary
Ps here is a picture of a shy bloke who was in attendance
Garys Teatowels
Well they are a hell of a lot cleaner than that ACDO u were using on them in your Matchbox Keymatic.
I had to start on the stains somehow.
Im no slut............
OMG....
i have just pi$$ed my pants with laughter!
You really do have the knack for the funny caption competition. Brilliant. Just brilliant.
Paul
keymatic with impeller. Need somme help again!
hello,
I progress in repairing the keymatic...
Thank you for the information on water levels and documentation. So I repaired the hoses, but in trying to operate, there is a leak at the impeller with water splashing when it turns. My questions are:
Can we still find a gasket and where?
Otherwise, how to disassemble (from inside the drum or rear?)
Have you a diagram with the parts?
In advance thank you for your help and sorry if my English is not great.
anyway I promise you that when the machine will completed I will make pictures.
Bert
Hi again and thank you very much for your reply.
Yes, the leak is coming through the back of the drum and there is no particular like. But there is a leak when the water reaches the bottom of the impeller, even when it does not rotate.
In fact, I dare not remove impeller because I am not sure of being able to assemble properly afterwards. Moreover, disassembly seems very complicated, and if the seal is wrong, how to repair because it is certain that this seal can not be bought anywhere! What do you think?
Otherwise, I tested the program spin: the timer and spin are ok. The valve also works but I do not know if the machine automatically stops the water because I have also put a seal between the door and opening
see you
Bert
