chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #21 Hoover A3110 Washing Machine Restoration Part 2
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #22 Hoover A3110 Washing Machine Restoration Part 2 Spring placed back over suspension arm
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #23 Hoover A3110 Washing Machine Restoration Part 2 Only the best will do!!!
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #24 Hoover A3110 Washing Machine Restoration Part 2 Nylon shroud ready for final fitting.
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #25 Hoover A3110 Washing Machine Restoration Part 2 New anti-twist suspension kit now in place - one down one to go!!
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #26 Hoover A3110 Washing Machine Restoration Part 2 2nd Old one removed ready for repeat performance!!
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #27 Hoover A3110 Washing Machine Restoration Part 2 2nd arm done and nearly in..
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #28 Hoover A3110 Washing Machine Restoration Part 2 Both arms complete and the chasis given a coat of rustoleum..
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #29 Hoover A3110 Washing Machine Restoration Part 2 Pump ready to be fitted back onto bracket with two new screws & nuts
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #30 Hoover A3110 Washing Machine Restoration Part 2 Suspension Arms - check, Sump Hose - check, Pump -check, The terminal block you can see with white connector is for the motor..
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #31 Hoover A3110 Washing Machine Restoration Part 2 Right way up and now ready for tub inserted, rubber boot and door to be attached!!
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #32 Hoover A3110 Washing Machine Restoration Part 2 Attaching top tub springs and a few more wires...
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #33 Hoover A3110 Washing Machine Restoration Part 2 Springs attached...and placed onto her front for inner tub insertion..
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #34 Hoover A3110 Washing Machine Restoration Part 2 A smear of adhesive for the tub seal..
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #35 Hoover A3110 Washing Machine Restoration Part 2 Inner tub being placed back into the outer tub - just noticed the Welsh Dragon giving its approval - this renovation is taking place only 25 miles away from wenst it was made in the Hoover factory in Merthyr Tydfil, South Wales...
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #36 Hoover A3110 Washing Machine Restoration Part 2 Having made sure the heater is placed over the freshly painted bracket we can now commence the bolting down
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #37 Hoover A3110 Washing Machine Restoration Part 2 many hands make lite work
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #38 Hoover A3110 Washing Machine Restoration Part 2 And round again to tighten, clamping the rubber seal firmly for a water tight seal..
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #39 Hoover A3110 Washing Machine Restoration Part 2 Attaching brace bracket and heater / thermostat wiring loom
chestermikeuk Well-known member Platinum Member Joined May 29, 2001 Messages 7,419 Location Rainhill *Home of the RailwayTrials* Merseyside,UK Mar 9, 2014 #40 Hoover A3110 Washing Machine Restoration Part 2 Tub secure - check, nuts tightened - check..
