JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Another constellation restoration.
This one is another Ebay find and cost £20.
I seem to have lost some of the Photos again, anyway in order of dismantling ready for powder coating.
Lid with handle removed, usual rusting hulk.
hotpoint 95622
Vacuum chamber.
hotpoint 95622
Motor out, bearings are shot, turn the fan by hand and you can feel the play and feel the crunching.
hotpoint 95622
Motor mount and the base of the machine.
I always take a photo so that when I rebuild the machine I’m reminded which way to refit the mount.
hotpoint 95622
Rubber mount
hotpoint 95622
Vacuum chamber, motor cover
Drilling out the rivets with a 3mm bit.
hotpoint 95622
Drilling out the rivets holding the flotation ring.
hotpoint 95622
Some times you get one pig; the rivet keeps spinning, so wedge it tight with a screwdriver between the two parts helps.
hotpoint 95622
I win the struggle.
hotpoint 95622
Catch off.
hotpoint 95622
Body parts ready for a paint job.
hotpoint 95622
Everything else in the storage basket for safe keeping, all the rubber parts washed including the name badge, hose ring and ratings plate ready for reassembly.
hotpoint 95622
Stripping the motor, first mark the motor casing with permanent marker, so that the casings are put back in the same places when rebuilding.
hotpoint 95622
Marker two places!! I allways use a 4
hotpoint 95622
Motor screws removed and slowly pull apart.
hotpoint 95622
In two.
hotpoint 95622
Using a socket remove the bolt retaining the fan from the armature and then separate the fans and internal covers.
hotpoint 95622
Second fan and internal fan cover.
hotpoint 95622
Motor field windings on the left, armature centre and big ends, bearings on the right.
