triumphdolomite
I've finally got round to looking at some of the problems on my A3350 today. I think that I know where I'm going with the suspension refurb that it needs but I've been looking at the leak that took it out of use. Having removed the backplate and drum I've discovered a small hole in the tub above the suspension mounting bracket. I'm planning on repairing this with epoxy putty and have discovered that there is a chip out of the inner rim of the backplate where the gasket seats, this has been letting water into the gasket but its been containing it and rusting the lip on the tub. I'm hoping I can build this up in the same way too. The question I have is, should there be a bracket in the tub to hold the heater element? It looks as if the hole has been caused by the heater chafing on the tub,I think the heater must have been replaced shortly before I acquired it as it's very clean with no scale on it. If anyone has any suggestions I'd be grateful
Thanks
Ian
Thanks
Ian
