I'll give it a polish
Yeah, it's weird it looked quite clean and shiny until I took a photograph of it hehe I'll polish it up and take another photo!!
It's a very nice machine though, I have had absolutely nothing negative to report about it. It's exceptionally quiet, our sharp microwave is significantly louder than the Aqualtis spin cycle at 1600RPM!!!! When it's washing it's almost totally silent, you hear a very faint splash.
The wash results are excellent, it's cleaning and rinsing as well as my old Miele and significantly better than a Bosch machine that we had before!
Also the platinum wool cycle is just the most effective thing you've ever seen.
You start the machine and it immediately ramps up to distribution speed i.e. the clothes stick to the side of the drum and it gets them all balanced.
Then it starts to fill!
The wool is not tumbled, rather it's driven through the water stuck to the drum.
This goes on for quite a while then it stops and allows the wool to soak for a bit. Then ramps back up to distribution speed and empties and spins at 600rpm. Then holds everything at distribution spin speed and re-fills with cold water and does a rinse (never stopping the spin!)
Ramps back up to full spin
and on to the next rinse(s)
The wool comes out actually fully clean and smelling nice and not like damp sheep!
It seems to manage to distribute and balance the clothes very effectively, much more so than the Bosch we had before and the powerful AC motor makes a huge difference, there's no "nonsense" i.e. it can just pretty much do anything with the drum as it can create huge torque and it uses it very effectively and can vary the speed from 0 to 1600RPM and anything in between pretty much at will.
I've seen one with the top off and yeah, I have to agree it's remarkable how little is in there!!! It's quite literally just a huge drum.
The control system is moved down to the back right of the machine and links up to the control panel on the door via a single digital connector about as thick as a USB cable. There are no wiring ribbons or anything like that that you find in older digitally controlled machines.
The 'box of tricks' that controls everything is just about the size of a brick with a large heat sink on it. That does all the switching.
I would assume the heat sink is for the inverter circuitry that controls the motor.
Having everything down there also means that there's very little wiring as the components are all located beside each other i.e. motor, pump, heater, thermocouples, level switch etc. So there is very little need to have many wires running around the cabinet.
