<span style="font-family: arial,helvetica,sans-serif;">Hi Matthew,</span>
<span style="font-family: arial,helvetica,sans-serif;">Sorry for the delay in the MicroProfile post.</span>
<span style="font-family: arial,helvetica,sans-serif;">You're not far off in your guess, the MicroProfiles spun at 1200RPM, 1300RPM or 1400RPM, for about 17 to 20 seconds.</span>
<span style="font-family: arial,helvetica,sans-serif;">Programmes on the 9566 were as follows, printed as they are on the fascia...</span>
<span style="font-family: arial,helvetica,sans-serif;">01. 95ºC White Cottons.
02. 60ºC Colourfast Cottons.
03. 60ºC White Nylon.
04. 50ºC Coloured Synthetics.
05. 40ºC Non Colourfast Cottons.
06. 40ºC Acrylics & Wool Mixtures.
07. 40ºC Machine Washable Wool.
08. 30ºC Silk, Printed Acetate.
09. 95ºC Special Finish Cottons.
---. 40ºC Mixed Wash (Includes 04 hr Soak period, same as my Servis Sapphire 9635 & 9700).
---. 40ºC Quick Wash (035 mins approx).
---. 40ºC Prewash.
---. ----ºC 1 Rinse & Delicate Spin (800RPM).
---. ----ºC 3 Rinses & Super Spin (1400RPM).
---. ----ºC Super Spin (1400RPM).
---. ----ºC Fast Spin (1000RPM).
---. ----ºC Delicate Spin (800RPM).
I'm going to quote the sequence for programme 2, for the cycle sequence:
01. Fill with water.
02. Heat H2O to 30ºC, interspersed with tumbles.
03. Wash laundry load at 30ºC.
04. Heat H2O to 40ºC, interspersed with tumbles.
05. Wash laundry load at 40</span><span style="font-family: arial,helvetica,sans-serif;">ºC.
06. Heat H2O to 50ºC, interspersed with tumbles.
07. Wash laundry load at 50ºC.
08. Heat H2O to 60ºC, interspersed with tumbles.
09. Wash laundry load at 60ºC.
10. Pump out wash water & spin at 095RPM & 400RPM burst.
11. Fill & Rinse 01.
12. Pump out rinse water & spin at 095RPM & 400RPM burst.
13. Fill & Rinse 02.
14. Pump out rinse water & spin at 095RPM & 400RPM burst.
15. Fill & Rinse 03.
16. Pump out rinse water & spin at 095RPM & 400RPM burst.
17. Fill & Rinse 04 (Softener rinse).
18. Pump out rinse water & spin at 095RPM, & 400RPM burst, stop & AntiCrease tumbles, (Start Spin Dry).
19. Spin at 095RPM & 400RPM burst, stop & AntiCrease tumbles.
20. Spin at 095RPM & 800RPM burst, stop & AntiCrease tumbles.
21. Spin at 095RPM & 1000RPM burst, stop & AntiCrease tumbles.
22. Spin at 095RPM & 1000RPM burst, stop & AntiCrease tumbles.
23. Spin at 095RPM & 1000RPM burst, increase to 1400RPM for 20 secs, stop & AntiCrease tumbles.
24. End of cycle, display reverts to 0 & indicated by three audible beeps every 058 secs until door is released or machine's switched off.
Button selections, left to right are:
Wash/Spin Progs.
Dirt Level.
Half Load.
Rinse Hold.
Spin Speed.
Delay Hours.
Start.
On/Off Security.
Door Release.
Drawer Lock (Turn only).
Dirt Level options available:
Light.
Normal.
Heavy.
Profile Prewash/Normal.
Profile Prewash/Heavy.
Programme times: Unsure for rinses & spin dry & spin dry only cycles!
01. 95ºC White Cottons: (Heavy) 110 mins (Normal) 140 mins (Light) 075 mins.
02. 60ºC Colourfast Cottons: (Heavy) 090 mins (Normal) 100 mins (Light) 050 mins.
03. 60ºC White Nylon: (Heavy) 090 mins (Normal) 100 mins (Light) 050 mins.
04. 50ºC Coloured Synthetics: (Heavy) 085 mins (Normal) 090 mins (Light) 045 mins.
05. 40ºC Non Colourfast Cottons: (Heavy) 060 mins (Normal) 075 mins (Light) 045 mins.
06. 40ºC Acrylics & Wool Mixtures: (Heavy) 060 mins (Normal) 075 mins (Light) 040 mins.
07. 40ºC Machine Washable Wool: (Heavy) 055 mins (Normal) 060 mins (Light) 050 mins.
08. Silk, Printed Acetate: (Heavy) 060 mins (Normal) 075 mins (Light) 040 mins.
09. 95ºC Special Finish Cottons: (Heavy) 110 mins (Normal) 140 mins (Light) 075 mins.
---. 40ºC Mixed Wash: (Heavy) 240 mins.
---. 40ºC Quick Wash: (Light) 030 mins.
---. 40ºC Prewash: 030 mins.
Oh btw, Matthew, my Servis Sapphire 1300 Washer Dryer 9635 & 9700 (pictured below) 9635 (left) 9700 (right), operate similarly to how the 9566 operated (even though the 9635 from 1989 & the 9700 from 1990), came before the MicroProfiles, so it's the other way roundreally, as the 9566 was from 1994.
My two Sapphires are built using pumps from Hoover, & motors from Hotpoint (the GEC types), so they sound Hotpoint like, even my Bosch WFT sounds Hotpoint like when it's tumbling.
The link below, shows the rinses, rinse-spins & spin dry of the Sapphire 9635, there'll be more from the 9700 when I return it home.
<span style="text-decoration: underline;">
You will need to slide the position marker to the start as for some reason the vid refuses to start at the beginning, it only starts at 08:19, instead of the start!</span>
CJ
</span>
