hotpoint not spinning out all of the water
hotpoint80
Member
Apr 27, 2007
13
Hey all whats up i've posted here before about my hotpoint if it helps the model number is WLW1500BBLAD anyways the question is that during the final spin and when the clothes are all done spinning some remain wet and when i hand them to dry i have to wring out some of the water,what is causing them to remain wet i mean the machine spins normal since it is only one speed so if anyone can help i would appreciate it to fix the problem.
Could be something blocking the drain outlet in the outer tub. GE/Hotpoints pre 1995 machines have a tendency to float small items into the outer tub. Unless the drain hose has been changed, it should be corrugated plastic, which usually doesn't kink. Hope this helps!
hey guy's thanks for helping i'll check it out and figure out the problem if nothing hasn't changed i'll ask you guy's again.
