seeitrun2006
Robert,
Thanks for recently posting Hotpoint washers on the picture of the day. It really takes me back to my childhood.
I have a question for AWO memebers. Growing up we had two low end Hotpoint washers. One purchased in 1959 and it lasted till 1971. It was then replaced with another low end Hotpoint washer in march 1971. Needless to say the 1971 Hotpoint did not last as long as the 1959 Hotpoint. We only got 5 years use out of the 1971 model before the timer blew up and shorted out the motor. My Mom then replaced it with a Maytag set in 1976.
Both the 1959 and 1971 washers were timed fill. The 1971 model had the same timer set up as the POD. Our housewhole water came from a well not city water. City water had much better pressure. On the well we did not have good water pressure. The washers would fill just fine as long as we used the warm water setting for the wash. When filling for the rinse the washer would never fill up all the way because it used cold water for the rinse. Of course when the water came on for the overflow rinse the tub would finish filling.
I noticed on the ad on the picture of the day states the washer is metered fill and timed. In the day I thought all Hotpoint washers were timed filled (not metered) prior to GE doing away with the Hotpoint solid tub washers.
My curious mind would like to know!
Thanks!
David
Thanks!
David
