turquoisedude
Turquoisedude does it again... No sooner do I get a 'new' washer into the Ogden Laundry than it starts misbehaving on me. Well, after two successful wash loads anyway...
The trouble is with the 57 Hotpoint Automatic (model 11JK31). During initial testing last year it was spinning fine - or so I thought. I did a load of sheets a couple of weeks ago and I was surprised that they were still quite wet (and I mean wetter than they would have been coming out of the GE Combo on 'Drip Dry'...). The next load I did was even worse - the wash water did not spin out of the tub. After the rinse, the results were even worse...
I didn't do anything to the machine for nearly two weeks; my theory was that a persistent water drip I had noticed coming from the water inlet hose had gotten the clutch assembly or belt wet, caused some slippage, and prevented the washer from revving up to a full-speed spin. So I filled the tub and set the machine to spin right away. It worked fine - the tub drained out and seemed to come up to an adequate spin speed.
So yesterday, I tried a load of shirts... I had the same outcome as two weeks ago! Look at how much water was left in the tub at the end of the final spin:
