dyson2drums
Hello all
I replaced the heating element on the Hotpoint WMA58 a few weeks ago. However it still isn't heating
The wires all seem fine that connect to the heating element itself. Could it be the opposite end connections of the wires being loose or something? If so, where are the opposite ends of those wires?
Also, the wash process is normal, nothing seems wrong with that. The temperature dial is working too as when I select 'no heat' it fills with cold water and when I select 50oc+ it fills with hot water.
Any help will be much appreciated.
Thank you
Thank you
