How do I remove an old Maytag agitator shaft seal?
volvoguy87
Jul 19, 2006
2,571
Cincinnati, OH
Elginkid and I have been working on Classiccaprice's 1964 Maytag A702 and finally were able to cut off the stuck agitator spline. Now I'm stuck. How do I remove the washer and old rubber seal shown in the pic so I can replace the mounting stem?
Dave
Well, based in the fact that I couldn't tell that the piece in question was rubber, I'm gonna go with the likelihood it should be replaced!
Wes
First remove the stop ring seal as Combo52 mentioned.
Then tap the washer from underneath with a drift or other suitable tool. If that fails, grab it with a channel lock pliers and twist gently. Its probably just seized on there from corrosion and 50 years.
