No offence meant
But issues lie in not knowing what you are doing exactly, then throwing various things at a wall to see what "sticks".
Problem is each treatment that doesn't work can (and very well may) be not only failing to remove marks, but causing them to become more permanent.
Chemistry (organic) is a professional launderers best friend, as such applies here as well.
What you've got is a "combination mark", one that is made up of a few or several different substances with each responding to various treatments.
Sunscreen marks are caused normally by substances much like red wine and cumin abhor alkaline pH, but respond to acids.
In commercial setting there are two ways of dealing with such marks.
First involves what your dry cleaner or small laundry likely would try; individually pre-treating each mark ensuring it is removed before going onto the wash. The other is an intensive "reclaim" program using strong chemicals, hot to very hot water with *many* cycles. This allows them to treat a large amount of marked linen at once rather than individually.
Idea is to first either remove the acid stain using like, (oxalic acid or similar), then using a high pH (alkaline) bath to counter the acid and remove substances that respond (fats, oils, grease, etc...). The latter can be simply one step/bath or washing in a detergent with a strong pH level. A bleaching cycle may follow, then many rinses. Nearly all this (except for last final rinses) are done in hot to very hot water temps.
Happily enzyme treatments often are effective in breaking down "acid" based stains like tannin, cumin, etc.. Long as they are done properly and given a chance to work (long enough contact time).
Chlorine bleach soaking is nearly universally useless. Marks able to be removed by that substance respond in five minutes or less. Hotter the water temperature faster the bleaching action. Longer periods simply allow greater contact time and can (often do) result in weakening or outright damaging fabrics.
http://www.thelaundryforum.com/forums/chemicals/pink-stains-mainly-at-summer-time-t1342.html
https://www.nytimes.com/2018/06/30/smarter-living/mutard-ketchup-berry-dirt-grass-sweat-stains.html
https://lenoir.ces.ncsu.edu/2013/08/mysterious-orange-stains/
Marks caused by sunscreen are *very* common and there are scores of hit pages on Google or elsewhere. Thing is to follow advice that will work instead of old wives tales.
