How does a new Speed Queen FL compare?
bobbyderegis
Dec 30, 2005
1,606
Boston
Hi All:
I know this has been discussed ad nauseum before, but since I never paid attention, could anyone give their opinions of the Speed Queen front loader? I know it has a fairly short cycle time, as compared to others. I recently discovered that they are sold in Milford, Massachusetts, an hour or so west of Boston. (they sell the top loaders, too) Is the quality good? Would one opt for a SQ as opposed to a Whirlpoop or LG? I assume that one could not put a SQ and Miele in the same comparision category. Thoughts or comments?
Bobby in Boston
They are also sold at Sozios in Revere. If you go to Speed Queen's website they will tell you where they are sold in the Boston Metro area.
The Whirlpool and LG machines have up to 4.0 cu.ft. capacity.The SQs have a 3.2 cu.ft.capacity.They're even smaller than the Frigidaires which claim to have a 3.5 cu.ft.capacity.
I have had all the above mentioned brands except the Speed Queens and all of them could do a queen size bedspread alone or all of the sheets and pillowcases in one load.However,my KitchenAid Ensemble(made exactly like Whirlpool's Duet)and L.G.front loaders easily washed the entire set.The bedspread, all the sheets and pillowcases,and a few bath towels!They had to be dried seperately but I normaly line dry my sheets and pillowcases anyway.
Sozio's? Wow, I haven't been in there in years. Not too far from Everett! I'll check it out. As far as capacity, I am not too concerned with washing bedspreads, just the everyday, average load. I think I would want a commercial machine to tackle a bedspread.
Bobby in Boston
New SQ FL's
In my dorms this past year of college there were brand new SQ's. They had that kind of squished circle of a door. And the cycle time was only half hour. They seemed to clean the clothes just fine. HOWEVER, in a different dorm they had FridGEmores, and I often made the 5 minutes treck to use these. They were non-commercial so I could put it through the heavy wash cycle and an extra rinse, just they way I like it. I took pride in knowing that I was the only one wondering, so ummm, does the school know that they're going to have to replace every single bearing in about 5 years??
In 1981, I lived in greater Boston for
four months. Longer if I had been able to get a job.....
I applied to Sozio's, but was not hired. I applied almost everywhere, from Caldor, to Sozio's, to Tufts,(almost got that one,) to MIT, to Polaroid.
I went from a couch in Arlington, to Roslindale to Jamaica Plain.
Lawrence/Maytagbear
Bobby
I have had the commercial version in my tenants for almost 7 years with not a problem.
They have a SS drum, SS outer drum, 4 FOUR shocks under the tub, SS BASE PLATE!!
The commercial machines use way less water than the residential machines. Which I love!
John L sells the residential machines
and by the way I'll meet you anytime at SOZIO's to kick the tyres!!
Speed Queen!
These machines seem real well built. I just don't like the fact they are so stripped of cycles and options. They are so good with their top loaders - why are the front loaders so basic?
Peter
I used Speed Queens front loaders at my dorm, too. Cleaning was gererally good even though the heaters were disabled and a 140*F fill ended up as 104*F at the end of the main wash. I always used pre-wash, however, because the main wash was so short and it also helped to pre-warm the machine and laundry if I wanted a hot wash. The warm fill was cold because the machines didn't have ATC and the cold water pressure was much stronger than the hot water pressure.
Rinsing was only so-so. After the main wash, the machine briefly sprayed the load with water before it went through a series a spin bursts. These bursts didn't do a good job at extracting sudsy water. The rinses were ultra short: the machine filled with water (up to where the boot meets the door glass), tumbled three times and drained.
The final spin was done at 1000 rmp for several minutes. But since there's no out-of-balance correction the machines sometimes had to abort the spin cycle and would then just sit there doing nothing until the counter counted down to zero. :(
All in all, they were good, quiet washers, but only mediocre at rinsing.
Peteski
SQ took these "homestyle" washing machines from a 120v range they had been offering for light commercial use for years. And like many commercial and laundromat washing machines, cycles are pretty limited and set by factory. Seem to remember some of the early SQ units did have "regular" controls for water temp, cycles, and so forth, but that seems to have gone by the boards when SQ made their big relaunch into the domestic appliance market.
Bobby
I bet I could talk my tenants into letting you do a load if you wanted to try one out. But John L ( who you know by now) told me that the residential models use more water than the commercial ones. My commercial machine looks like what Robert is always saying about modern front loaders- "just toss in clothes soap and a wet towelette for modern cleaning" The clothes do look just damp but the tenants have no complaints about rinsing or cleaning.
And the love the gambling roulette feature! Just love it!
I think the Speed Queen FL's big selling points include the stainless outer drum, and the right-hinged door. Don't know if the rest of the machine is built better than the average bigger front loader sold in the USA these days, but it's probably better than the original Frigmore and Neptunes. I would imagine that the main bearing is replaceable, as well, another good point. The downside includes the aforementioned too-short cycles. And you can't get an internal heater unless you get the model with the control panel on top. The flat top machines are non-heated only.
Don't know about how bad "short" cycles are, and perhaps poor results in SQ front loaders have more to do with laundry practices and or design than anything else. After all Milnor commercial and OPL washing machines have about the same short cycles, but according to reports and members here, they do the job quite well.
Of course there are several problems with front loaders that do not have internal heaters or good supply of "HOT" water. Commercial laundries and laundromats use recirculation pumps to make sure fills are hot, not cold, tepid, warm, then hot, which means water temperature may never be more than 100F. Also am wondering what type of detergent many reporting poor results with SQ front loaders are using. For best results one is probably going to need a good HE detergent designed to "hit and run", that is disslove fast and get the job done.
L.
I guess I've been spoiled by the heater-equipped Neptune 7500 and of course the various and sundry Mieles. Just did a load of whites in the 1918 in the workshop this afternoon. What a lovely machine. I'm tempted again to move it into the main house, but the Neptune refuses to die - and the Neptune, with its weak 110 volt heater, really needs an external water heater, which the workshop lacks.
A proper laundry room probably should also house the water heater for the home. That's how the last place I lived was set up, but that was perhaps the only good thing about the place ;-). The "laundry room" was really a landing, what looked like an enclosed back porch, and there was room only for the water heater and one washer - water heater in back of the washer. A stacked unit could have worked there, I suppose. The '83 Whirlpool top loader liked to waltz around that tiny room. And at the time I really had no clue about laundry, proper water temps, etc. But I was aware enough to notice that when Huish pulled STPP from "Clout!" in the 90's, that the cleaning performance plummeted.
Report on SQ front loader-by owner
There SQ front loaders are truly built like tanks,but in real world use aren't what they could be.I'm on my second one,the first walked terribly during spin-it would literally chase you!It was replaced with another(TOL with heater-rear control)that is better,but still not what I expected from this price machine.It "helicopters",to use SQ's terminology.The newer unit has a different boot-seems to be a little more pliable,but is also not as wide.It leaves a big crack between the edge of the boot and the edge of the tub.A footie,a washcloth,or my wife's panties lodge there occaisionally.This second machine is better than the first one-it simply was not usable,but the second one vibrates during spin too.The tub jumps up and down,and with the narrower boot allows it to move backward and forward too-often the door is moving in and out during the pulse spins.Noisy.Not every load,but over half of them.SQ customer service is great-they do care,but are fighting a losing battle until changes are made to the machine.My retailer stopped stocking the FL machines,but still offers the TLs,which are wonderful.The dryers are great as well,as good as any I have ever used.I'm going to sell my machine,if anyone has interest,let me know.
Tom
One would think that...
with all the experience SQ has with commercial FL machines in the laundromat industry they could build a better machine.
Maybe with the eventual redesign they will add more wash options than the current model has.
Methinks the problem lies with costs versus returns. SQ has not exactly gone the mass merchandise route, selling to big box stores and the like, and that sort of volume is what they will need to move units. Without high sales cost per unit is going to be more than average for the same size machine, however Whirlpool and others have uber-sized front loaders that offer more features for the price. Make no mistake about it, today's consumer is after bells and gimmicks, not a unit that will last the duration. Most consumers simply do not view "major appliance" purchases the same way their parents and or grand-parents did. More likely than not, the washer will be kicked to the curb, family moved and left it behind, etc; long before what long "lifespan" the machine had.
IMHO SQ should have stuck to the earlier version of "homestyle" units, still sold in Canada under "Hubesch". Many of those units were sold to US military bases and are still kicking, despite the abuse.
Laundress,I agree
Most consumers are much more interested in bells and whistles than quality-if fact,most MISTAKE bells and whistles FOR quality.The very simplicity of the SQ machines is what drew me to them.I do not need 25 cycles-I do not have 25 kinds of clothes!Make no mistake,these are well built units-but they desperately need fine tuning in the suspension department.
The lack of frills is true: the SQ FL I saw recently was bare bones. I too don't need all the bells and whistles. Interesting about the noise and boot of the FL. I looked over the TL SQ too. It is still built like a tank. It sounds like the SQ FL is good, but nothing to rush out to buy.
Bobby in Boston
OPL
On premise laundry, military barracks, housing, etc. Laundry is "free" meaning no coin slots. Afterall it's not like anyone off the streets can get in, and how much laundry does your average enlisted man/woman, or officer have?
Was watching the PBS program "Carrier" the other night, and apparently the washers and dryers on ships and submarines are "free" as well. IIRC this particular program's ship had Neptunes, or maybe it was SQ, didn't really look beyond knowing it was a front loader. Interesting item: while the machines are free, apparently many military persons pay someother military person to do his/her laundry. On the "Carrier" program, one was paying someone else ten or so dollars to do his wash, but apparently the "launderer" wasn't separating whites from darks, so the customer took his business elsewhere.
Have seen many auctions on fLeaBay and elsewhere from sellers hawking used SQ washing machines from military bases. Don't know why the Armed Services only keeps machines for three or so years per contract, but there you go; our tax dollars at work.
Mine has never walked
in fact it is installed on the 3rd floor of my house so if there were any issues it would be major there for syre!
There is a problem with two little $5 nylon pins installed on the drop down door!
They are crucial to the machine not vibrating in spin. The early ones were made wrong and take 5 minutes to replace. Also they do wear out after 4 years use so need to be replaced.
You will know the cabinet will shake violently and when you out the new ones in whamoo it works like a charm.
Also the boot is indestructilbe and ALSO MOST IMPORTANT fits the early 1955 and Pre-1955 Bendix washer and Combos!!
A tip from DarthJetcone...............
