How Is Everyone Keeping Warm?
"I remember several years ago during a cold winter, peoples' boilers shut down..."
Read about that unfortunate situation. Made worse by the fact one can no longer purchase anything else but condensing boilers in UK (IIRC), people felt they'd been done. First by being forced into having the things, then dealing with the aftermath.
https://www.theguardian.com/uk/2010/dec/27/condensing-boilers-freeze-uk
City of New York for some time now has been trying to force certain buildings into replacing their old oil (often converted from coal) boilers to new condensing; many aren't having it and refusing.
We have those condensing boilers too, but overhere there is always a drain pipe installed under the boiler to catch the condens water. I have never seen an installation where the condens water is lead outside.
Not that there is a risk of freezing here at the moment. Today we reached 53 degrees F.
electric baseboard heat
or any baseboard heat: You can improve the effectiveness of it by training a small fan like a smaller, but not miniature, Vornado down at floor level to drive air through the things and pull more heat out of them. It also serves to push cooler air near the floor into the heating units which helps remedy the stratification of heat at the ceiling and cold on the floor that you can get with baseboard heat.
me & my big mouth...
<span style="font-size: 14pt; color: #008000;">I've been watching some of the weather reports concerning the bitter cold in other parts of the Country. I realize that although my earlier comment about the unusually warm weather here in the desert was done in good fun, the freezing temps are nothing to joke about. Having lived my entire life in California and never been in zero degree weather I guess I'm not aware of all the problems and obstacles the cold throws at you. Check back with me in the summer when it's 120 outside.  </span>
@foraloysius - UK & Irish Drains are very different!
In most buildings, other than multistorey apartments or larger commercial buildings in these islands the drains (except toilets) run to outdoor gulley traps. They either just point directly into the gully and flow in through the grille, or they enter just below the surface.
In most setups, we don't tend to connect drains from sinks, baths, showers, washing machines and dishwashers etc directly to a sewer line. The gully trap provides a physical and complete separation.
For that reason, you would typically also run a gas boiler drain to an outdoor gulley. There's no real way of connecting them to a floor drain as they don't generally exist.
It's fine in the mild conditions of the south of both islands but because of the small diameter and low, constant, flow rates they can freeze in a way normal drains here wouldn't and you can get temps low enough to do it.
It's an extremely bad design in my opinion. They really should be connected to a normal sized drain pipe not at risk of freezing.
I can't see any possibility of condensing boilers being connected to to an freezable drain in the USA as the temperatures are much more extreme. I would guess that regulations there, used to dealing with freezing conditions, wouldn't allow it.
Boiler condensate drain
I think lessons might have been learnt (by some installers) from the frozen external boiler drain fiasco.
My particular boiler drain setup has the typical plastic 3/4" drain piping (with lovely right-angles here and there!), leading into the bathroom. (The boiler is in a cupboard, in the hallway just outside the bathroom).
The boiler drain piping is connected in the bathroom, to the bathtub drainpipe via a T-junction and appropriate size reduction adapter.
I presume that the bath drainpipe was employed because it is lowest in height, thus assisting in gravity drain/siphoning of boiler condensate. And I suppose that with 'used' bath water occasionally rushing past the T-junction, there might also be a small degree of suction helping to drain the condensate pipe.
12F in Music City!
It's 12F here in the Music City as the music note dropped at midnight. I'm at work but I'd much rather be home.
A few days ago, I was sitting in the living room watching television and noticed a chill in the house. Tony was up fumbling around already so he went to the digital thermostat in the hallway to bump the heat up a degree or two, but it said the heat was already on...no it wasn't. We turned it up to 78 to see what happened...nothing. My satellite dish is right beside the furnace and when the gas lights it sends a couple of lines of interference across the television screen. I had noticed while watching TV that when the furnace combustion fan came on (it's right outside the living room window) I saw the static lines go across as usual. Then a few seconds later I saw them again. In my little brain I took note but didn't think much about it. So...I went outside and took the access door off to investigate. Ran in the house, turned the heat back on and ran back outside. Combustion fan came on, then heard the buzz from the ignition module, but did not see the spark plug fire. It was dark outside so I kept looking around in the cabinet...then I saw it. Just like a spark wire in a car, it was jumping fire to the cabinet and shorting itself out. I guess the insulation had weakened enough that the spark took the path of least resistance. I just wrapped some electrical tape around that spot and moved the wires around a little, turned the heat back on and BINGO, the spark plug fired and the burners lit and we have HEAT! I'm so glad I didn't have to call out a service guy.
Temp 3:30am 34°F @ my house.  46°F on the car out of the garage, varied 34°F to 32°F to 33°F on the road to work.
Current forecast 40°F/27°F today, 34°F/23°F Tue, 49°F/27° Wed, 50°F/30°F Thu.
-4 here in central MA. I think my furnace is unable to keep up with setting the furnace above 69F. I had it at 70 and it doesn't seem to be shutting off. So I put it back to 69. During normal winter temps I keep it set at 67 and it seems fine.
@Rolls-rapide
That also make sense from the point of view of protecting drains too. Boiler condensate (depending on the exact makeup of your natural gas supply) can be mildly acidic and can etch and dissolve concrete, porcelains and earthenware surfaces. It makes sense for the boiler drain to flow into a trap that has a lot of use eg : from a bathroom, a kitchen or best of all a washing machine. A good flush out prevents problems.
I think in the early days of condenser boilers growing use, a lot of plumbers were fairly clueless about the potential issues with the drain lines. Maybe they’re learning!
"come here closer and snuggle up
baby".
Checked the high for today in Phoenix. 74 F. They say everyone out west will be moving to the great lakes states for the water soon. If they aren't submerged under water again like after the last ice age.
Jet stream, El Nino, La Nina~, colder ocean currents, who knows. It's as much of a crap shoot to prove or disprove climate change and planet warming.
Outdoor temp is reading 32°F at 10:00a which is less than at 3:30a.  "Official" report is 33°F.  The thermostat app at work reports 31°F (outdoor, not in the building) but there are no outdoor sensors on the units so I don't know what/where is that reference source.
According to one of my weather apps it did reach -8 last night. I'll check the logs in the thermostat when the heat finally shuts off. The downstairs furnace is running continuously in first stage but hardly going into second stage surprisingly. Normally it would be cycling into second frequently at these temps.
I looked out the window and I could see everyone in the neighborhoods furnaces were running, the gas company must love that.
