Here you go:
You will need to disconnect the leads and then test the following three combinations.
6" 1450 watt 3-wire burner: black to blue - 105 ohms, blue to red - 73 ohms, black to red - 52 ohms
6" 1250 watt "Speed-Heat" 2-wire burner (1955 on): black to blue: 10 ohms
8" 2050 watt 3-wire burner: black to blue - 70 ohms, blue to red - 50 ohms, black to red - 38 ohms
8" 2600 watt 3-wire burner (1958 & 1959 only): black to blue - 81 ohms, blue to red - 47 ohms, black to red - 36 ohms
