never had to adjust the air mix.....as long as its a blue flame, with some yellow tips, your good to go......give it a few cycles on/off before you decide it needs adjustment.....and you can adjust while in operation, probably best this way you can adjust small increments at a time....
I have seen a 50/50 yellow/blue at the start, and then taper to the 90% blue....even if an adjustment is needed, keep an eye on it for a while.....once set, your good to go....
happy drying!
