Wholelottared
That was an interesting video.
Now, I'm not quite sure if running the dryer without the side panel is an accurate way to measure the temp inside the drum. Even running my old Siemens condenser without the water tank would result in (very slightly) lower temp due to the increased cooling air flow - and that dryer had like four times the heating power of the heat pump.
Also, and this could be a auto translation error, but he said that BSH dryers never reversed, don't do it right now and probably never will. None of this is true.
In the end, I'd suggest you go to Amazon and get yourself some thermometers. Mine cost next to nothing and are similar to this
https://www.amazon.com.tr/ARCELI-Te...72&sprefix=termometre+akvaryum,aps,144&sr=8-2
As an Amazon Associate we earn from qualifying purchases.
