How to make line dried clothes soft
norgechef
Jan 27, 2012
308
Saint George New Brunswick
Does anybody know how to make line dried clothes soft? i use fabric softener but when the clothes get taken off the line they are always crunchy and hard to fold, but they do seem to smell good, I just can't figure out how to get them soft...
You could try tumble drying them on air fluff (no heat) for a few minutes. This will help to separate and fluff the towel loops. Then hang them on the line. When they are nearly dry, stick them in the dryer again, this time on heated dry, to finish them.
They may not be as soft as completely machine dried (there's something about heated drying of wet towels that makes them softest) but they will be softer than if 100% line dried.
Another, non dryer method, could be to shake out the towels thoroughly and vigorously before and after line drying. Similar tactic as the air fluffing, just more work for you. I haven't tried the shake technique, myself, but it might work.
Me, I tried line drying for some years using the above air fluff technique. But eventually I got tired of moving the towels back and forth between dryer and line, and now I simply spin them as fast as possible and then machine dry them all the way. The cost in energy is fairly low. Sheets, blankets, bedspreads, comforters, mattress pads - these all get line dried, weather permitting. They don't need to be soft and I kind of like the starched effect that line drying can give to all cotton sheets. The synthetic bedspread (polyester) is soft no matter how it's dried.
Softening line dried clothes.
A friend of mines mother does a lot of line drying and she said to dry things you want soft in the dryer for 15 minutes before hainging them up on the line.  I would imagine a small amount of liquid fabric softener in the rinse water (too much will waterproof fabrics) could help.
WK78
I use
The clothesline most of the time, we have the weather to be able to, and if I want the clothes to be soft, I do the 10 min thing in a warm dryer first, no fabric softener, and hang out!
Always works for me.
HTH
I use fabric softner and TRY to hang out on the lines when I can get to them to save energy. This winter/spring, so far has been a NO, got to use the dryer. I dont mind the sandpaper towels, but if there is a good stiff breeze, they seem to soften very nicely and a good shaking when folding them does help to relax the fibers.
