AlfredReed
- Joined
- Oct 16, 2013
- Messages
- 1
I have an old Kenmore Heavy duty Series 70 washer with two current problems that started both at the same time: 1) the agitator slows with barely a full load (used to be able to wash a substantial load) 2) when it spins there is a knocking sound as if something wooden is bouncing around when it spins. The agitator is one of the old single tower kind with the cap that screws off to reveal a threaded post sticking up. It would require a major effort to move the washer out to find the serial number -- I am hoping someone will recognize the type of agitator by the above description.
These problems began together along with the appearance of a small screw in the tub as though from beneath the agitator. I figured the screw maybe came from a pants pocket originally but when the other problems occurred I am thinking either something more than the screw came from my pocket and is still wedged somewhere, OR, the screw came from somewhere in the washer.
I tried to remove the agitator but after unscrewing the cap nothing else moved even with gentle prying up from underneath. I think if I could get the agitator off it would lead to a better understanding of it all.
If anyone is familiar with these (I'm sure these old agitators are common if they came with Kenmore)I would like to get advice about how to remove the agitator and anything else that could be helpful. If absolutely necessary I could take a weekend to get the serial number and/or shoot a photo of the agitator. Tahnks,
AlfredReed
AlfredReed
