Hundreds of Old Motors
blackstone
Jan 27, 2006
837
Springfield, Massachusetts
Just thought that you would want to see hundreds of motors on their way to China! I scrapped at least 500 motors earlier this year, saving only the Blackstone motors, as I am clearing out the store. My father bought and restored most of these motors. I tried to sell them, but without success, so they had to go the the junkyard. If you see a particular motor that you might have wanted, sorry, too late. Sure is a lot of manual labor involved here.
Scrap metal prices are historically high, and have been for the past couple of years, thanks mostly to China. For the motors, I got 18 cents per pound. Insulated copper wire goes for close to a buck a pound, which is why I was cutting off all the wire. Before throwing away any appliance, I save all the wire. Clean copper, without insulation, is over $2 per pound. Scrap iron, however, is hardly worth the work of lugging it around--just a few cents a pound.
I sure would like to know how recyclers can separate the copper out of motors. In the past, I have cut the windings to get out the copper, but that is very time-consuming. There must be some heavy-duty shredder that can chop up the motor frame. Time to Google.
Yes-SSI shredders could chop up the motor frames-and you can seperate the copper from the iron more easily.I used to dismantle transformers from transmitters by hand-now its just not worth it-better to have the transformers rebuilt-then resell them or use them for spares.Go to the SSI website-and watch the film clip of their shredder chopping up a torpedo-if it could do that-I would think it could cut thru most motor frames.
http://www.ssiworld.com
