HVAC Brands of the Past. Where are they now?
Actually, the Corvette Assembly plant in Bowling Green, KY is an old Chrysler Air Temp plant. The building actually looks like an old Chrysler plant because GM never removed the large blue trim band that runs around the top of the building. You still see a lot of old Chrysler Air-Temp units around here still chugging away. Years ago I lived in a house built in the early 70's that had a Chrysler unit in it. Worked well.
Neat info about the Corvette plant
I assumed it was all new.
When I was going to the University of Tennessee in the 1980s, many of the older buildings had Chrysler Airtemp window units. They were had the name lettered on them so large you could read it a couple of blocks away -- with teenage vision, that is. ;)
Thanks for the picture Greg.  My Grandparents unit could have been older than yours.  The outside casing was brown and was huge!  Your unit might have been a more "energy efficient" unit.
Tom
Your memory of your Aunts home with the Chrysler Air-Temp is great!  I remember these units (Window and Central) having much colder air than the units of today.  Bone Chilling air!
I have been in many homes for sale in the Atlanta area that still have the original Chrysler Condensers and Furnaces still running with a clean inspection for running!
One house that we were very interested in had an original Chrysler Gas Furnace that was paired to a Singer Condenser.  It was during July when we looked at the home.  The home was bone dry cold!  It was a great feeling! I knew before investigating the HAVC unit that it had to be vintage.  It was.
Sadly they declined our offer on the house.
Thermostats
Cleaning out files on external hard drive and found pictures I forgot about.
Here are some interesting thermostats that you may remember from your past.
Great thermostat pics, Brent!
Thanks for posting the many thermostat pics, Brent. There are some real classics there!
At my former church in Los Gatos, they had something that looks just like the Honeywell "TimeOStat" (but without the thermostat - just the timer) next to each of the thermostats (round classic Honeywells). The furnace would only operate if the timer was turned "on" or by using the sliding switch on the side of the timer. I imagine this was to ensure that furnace wasn't left on after morning church was over.
When I had my new HVAC system installed last May, I had them replace my old Sears 7 day programmable thermostat (which still worked great) with a new Emerson "SenSi" Wi-Fi thermostat. It works great and I can adjust the temperature or schedule any time any place using the iPhone app.
Bill,
Did you keep your old thermostat?  I have thermostats from homes that I grew up in when the furnace or a/c was replaced.  Some of them were truly ancient in the homes  growing up on New Orleans.
Your new Thermostat sounds very cool.
Brent
Brent, any of these thermostats are yours?!  I really enjoyed seeing these pics!
Here's one that I have.
Phil your "Weather Station" is so darn cool!
Some of the t-stats are pictures of ones I own.  (the very old HW)  I have two boxes of them SOMEWHERE!  Hopefully I will come across them soon.
I have tons of pictures of vintage HVAC units that were taken out of homes.  Replaced.  I did not know if there was an interest here to see them.
B
New lobby HVAC unit at work (after 30 years!).  With an Emerson (White Rogers) Sensi 'stat.  The trick about it is that the WiFi app is the only way to set a schedule, and is the only way to enable Auto-switching heat/cool mode.  The Mode selector on the unit has only Heat/Off/Cool (which does indicate which mode is active in Auto).  If it's on Auto mode and the mode is manually changed on the 'stat, there's no way to get it back on Auto except via the app.
My parents (and most other houses in the subdivision built at the same time) had Lennox gas horizontal furnaces...a few are still running and they were installed in 1968...my dad replaced ours with a Trane package unit in 1992 but that Lennox was still working, just inefficient. We had a York central AC unit connected to that Lennox furnace that was installed the year I was born 1971. They replaced their Trane a couple years ago due to heat exchanger failure, the new one is I think a Goodman product. I used to have a WeatherKing pkg unit...also heat exchanger failure (could have killed me) and I replaced it with an Amana (stainless heat exchanger lifetime warranty) that was built near here in Fayetteville, TN. My Aunt in Indiana had a Philco window unit with the Ford logo on it. Everyone I know who had a Carrier gas unit had big problems with it. Heil-Quaker had a plant near here also in Lewisburg, TN and Fedders had a plant here in Columbia, TN til it closed and they started using Chinese junk, and GE had a compressor plant here until sometime in the '80s I think.
I will load some pictures tomorrow.
They are on an external hard drive that I can't get to tonight.
B
Reznor
Here are a few pictures of Reznor Unit Heaters.  You may still see these still in use running in top shape like they did first installed 50+ years ago.  Many were installed in schools, businesses and the like where automatic heating and cooling was something new.  They were built like tanks and were meant to last virtually forever.
I will post these different units at random as I find them in files.
Brent
Janitrol
Beautiful Original Janitrol Units.  So many of these are still in use.  Janitrol had the "Dura Tube" heat exchanger.  They were also built like tanks!
Lennox
Beautiful Lennox Furnaces!  I see so many of these still in use in homes in my neighborhood.
Western Thinboy
I don't know much about this unit besides it was built in California which is odd enough.
Cute unit though and over 50+ years when it was removed.
Beautiful Modine Unit Heater
Love the colors and lines of this unit heater.
Reznor Unit Heater
I can remember when we lived in Billings Montana having a Reznor unit heater in the garage of the house we were renting on Parkhill Drive. The washer and dryer were located in the garage so it was essential to have the garage heated during the cold winter months.
Yes, Brent - I do still have my 1980's Sears 7 day programmable thermostat (made by White-Rogers, I think...). The original thermostat was one of those "generic looking" square ones with the sliding temperature control on top and a round thermometer with company logo (F/J) in the center.
I was tempted to keep using the old Sears thermostat with my new system (it was equipped for heat and a/c) but being able to control temps and schedules via iPhone app was just too tempting for me (think of those cold mornings when you decide to get up sooner than the thermostat schedule is set for!).
I just stumbled across a ca. 1939 brochure talking about Williams Oil-O-Matic. It's old enough to talk about converting existing furnaces (one assumes coal) to oil heat.
https://archive.org/details/YourGuideToOilHeatingAtItsBest
My favorite part is the claim that you "never have to visit the basement" once you have Oil-O-Matic heat. Funny thing...but I've never had any totally zero maintenance heating system. Although I suppose oil heat required quite a bit less effort than coal did.
Re Williams Oil O Matic
They, like GEs oil burner,were low pressure burners,these used a adjustable nozzle that rarely ever needed any attention,and could burn less expensive heavier oils cleanly and efficiently...they were more expensive to build than the standard high pressure oil burners,this and the fact most service men did not bother to learn how to correctly work on them,led to their demise, as well as the Wall Flame Rotary burners which also were very clean burning trouble free units,many of these units were giving 80 plus efficiency ratings in the 50s when the standard oil burner units were giving 60 to 75 percent efficiency...especially the GE units, they were complicated in that their control system was totally different than any other furnace,safer and better built also, but were way ahead of their time.
The 1st Modine heater that I've seen was a wall-mounted vent-type system, near the floor, in the entrance way at my city library...
Wonder if it got replaced before the whole library had been remodeled or if it got kept there until its "whatever last day"...
-- Dave
Davey7
Thanks for posting the brochure of the "Iron Fireman Selectemp"!
So interesting.  I wonder if any homes are still running this system?
No electricity needed.  Every room had it's own unit with thermostat and built in fan that was run from a steam turbine!  I would love to see this type of system!
Brent
