I Cut The The Cord!
Movies! Rocks!
Am seeing so many great and wonderful films that not even cable gave.
Just this past week:
Drive A Crooked Road - with Mickey Rooney
Sniper - A great and largely unknown film noir set in SF.
Phone Call from a Stranger - Another largely unknown but great Bette Davis film.
Tonight it is a double feature: Sabrina with Audrey Hepburn and Separate Tables starring Rita Hayworth.
We're watching that movie Funny Face right now. Well, Karen is anyway. It seems we will have two antenna positions to cover everything. Maybe this fall I'll install the rooftop antenna and then I won't need to play musical antenna positioning.
Have Found The Sweet Spot For Ours
May have to move things about every now and then, but otherwise things are fine.
It could also be the type of antenna you are using. IIRC those flat things pick up signals in an a random sort of way, that is you cannot "point" them to where the signal is strongest. Have you tried using your television's or converter box's built in signal meter?
The Winegard Flat Wave antenna was just a interim measure until we can get the huge Winegard antenna up on the roof. I thought I ordered the regular Flatwave antenna, but I got the Flatwave mini, which is designed for close in urban locations. And we are 39 miles from the antenna farm from which all TV signals for the area are broadcast. So we are luck to have what we got so far.
I'm not anxious to get up on that roof. It is very, very steep and slippery. I'll have to rope off the chimney to make sure I don't slide off. But we have a nice cold front blowing in now, first one of the year. Tomorrow it'll only be 80F for a high!
With the Roku depending on model under the network setting you can choose wired or wireless, from there you can enter your SSID and your password using the on screen keyboard.  You should only have to do it once.  Given an option I ALWAYS use a wired network.
If you want to have a little fun, there is a service called UNBlockus where you can change your Netflix country.  I was using it to get Super HD, but NF is rolling that out everywhere now.  But it is fun to "move" to England, Sweden, Canad and Mexico among others and see what is available there.  Often stuff is showing in other countries before it is available here.
Laundress:
I was actually thinking about having a antenna installation company come out and do it for me. I feel like I am getting too old for this type of thing. When I was younger I installed quite a few, but nowadays.....
@whirlcool
Well if things can go that way it does seem a more safer option. After *thinking* about getting up on one's roof versus actually going are two different matters. Have actually read accounts in OTA group boards where many a husband was strictly forbidden by SWMBO from even getting the ladder out, much less going up onto the roof.
Who is the SWMBO, haven't heard that term before.
Other strange thing I have noticed:
I had to reset the color & hue level on the tv when I went to OTA. Seems like DirecTV required more color intensity and the hue was quite a bit towards the green. Now the normal factory default looks perfect.
We can't get the Houston CBS affiliate, Channel 11, but strangely enough we get the Bryan/College station affiliate just fine. Channel 11 is 39 miles away where Bryan is about 70 miles away. Just strange I thought.
OTA Signals
Much will depend upon factors such as objects in the line of sight from the antenna to your home.
There are a few good websites that will tell you what *should* be available OTA in your area. You simply plug in your address and up comes the data.
In the world of OTA roof/outdoor mounted antennas give the best service for effort according to experts. If that cannot or will not be possible the next best thing are indoor antennas. Am sure you know already that there isn't any such thing as "HDTV" or "Digital" antennas. Those are marketing terms created by those seeing to sell things. Persons have gotten excellent reception of all stations, digital and analog using nothing more than old fashioned "rabbit ears" antennas.
http://www.tvfool.com/
One reason some channels may be problematic is the band they are on.
Some stations opted for the VHF freq. they had been on thinking it would carry further than the UHF counterparts, but in my case they simply locked themselves out.  I have a very high gain antenna I had imported for england 12 years ago when I went HD, it's UHF only where all early HD was located. Originally HD stations had 2 channels, the standard SD channel they might have been on since the 50's and a secondary UHF channel that was unused in the area.  There might have been a handful of secondary VHF stations around the country but most were UHF.  When analog broadcasting ceased the stations had a choice of keeping their original freq. or opt for the UHF freq the HD had been on. in some areas freq. got shuffled and stations ended up on a completely new freq, but that was unusual.
So if certain channels from the same vicinity do not come in the same it may be due to the fact your antenna is optimized for one band over the other.  A UHF antenna can pick up high band VHF if it's fairly local, but low band VHF 2-6, will not come in.  Just a note, a lot of stations now use virtual channel numbers.  My local CBS outlet is called Channel 5, but it actually transmits of UHF ch. 22.  So check into what the real  freq. channel for teh problematic station and see if your antenna can receive that freq.
As far as antennas go we have some friends who moved into a house that had an ancient antenna on the roof. Their house was built in 1954 and they think the antenna is the same age. They just took out the crumbling twin lead wire and installed 75ohm coax and they can receive HD television just fine with it. But then again they are only a few miles from the antenna "farm"
In Houston just about all the television stations broadcast from just one or two towers located in Missouri City which is SW of Houston quite some distance. That's why we call it "the farm". There are a few others that broadcast from Baytown and Conroe but most are Spanish speaking broadcasts.
The outdoor antenna I bought, a Winegard is about 7 or 8 feet long. But it only weighs about 3 lbs. I think the best bet is to assemble it on the roof or just have an antenna company come out.
We received our new Windgard amplified indoor television antenna. We bought it off of Ebay . We are 38 miles from the transmitter site. When we were using the Flatwave Mini we'd receive stations and get about 15-20% signal strength. It was a suitable picture but for some stations we had to move the antenna around.
So we bought the amplified version. We just stuck it up in the window and voila! with this new Flatwave antenna we get 85-100% signal. And we don't have to move it around at all. We even get about 8 new stations. This is so good that we may not need to install the rooftop antenna. And this is a good deal too. I only paid $24.95 for it with free shipping.
Most rooftop full VHF/UHF antennas are designed with elements that swing out and lock in place easily, so yes you can do the minimal assembly on the ground (like sorting out where the U-bolts will go) and then swing the elements into position once it's on the roof. Important to be careful around power lines as well as take the usual care when up on a roof.
We're a little spoiled for choice of really good channels here. If you do 'cut the cord' a small satellite dish will pick up a very large range of free to sure very high quality content mostly from the UK.
However, there is no way I'm cutting it. My 200Mbit/s internet comes bundled with cable TV and phone, so I'm stuck with it.
Ireland is a bit like Canada in so far as we are right next to a much bigger market, the UK so we have always had access to whatever is on air there too. In fact, that's what launched the cable industry here in the 1960s. Cable gave people access to 'overspill' programming that wouldn't have otherwise been accessible.
Most British channels, including BBC make themselves officially available here via pay tv platforms these days. So a chunk of your satellite TV or cable TV bill here goes to the BBC to pay for BBC 1,2,3,4 etc while Channel 4, E4 etc and most of the major commercial UK channels sell their own advertising here and broadcast an Irish version on cable / sat to gain ad revenues.
Back in the 1970s and 1980s BBC in particular used to do things like tell Irish callers to TV phone ins 'you shouldn't be watching us!!'
There was a famous incident where a kid phoned into a competition on some BBC programme and was on air. When the presenter figured out she was in Dublin he gave her a stern telling off and cut the call live on air.
They also used to go out of their way to 'shield' their transmitters to prevent overspill. So they'd have lower power in costal areas or areas facing borders.
Meanwhile Irish TV broadcasters were deliberately trying to be picked up in Northern Ireland to gain ad revenue.
We also had a lot of commercial music radio stations based here that targeted the UK in the days that BBC retained a monopoly and didn't like 'pop music'.
Long Wave Radio Atlantic 252 for example was probably the very last of that model. It used a transmitter so powerful that it annoyed the Russians by broadcasting commercial pop with news on the hour that was overspilling into the USSR lol
How the world has changed in terms of media access!
Apparently some things never change.
Although we can watch BBC overhere in the Netherlands and a few times somebody from the Netherlands was on the phone in "Saturday Kitchen", I can't view BBC programmes on BBC iPlayer. When I try I get this message:
"Currently BBC iPlayer TV programmes are available to play in the UK only, but all BBC iPlayer Radio programmes are available to you. Why?
If you are in the UK and see this message please read this advice.
Go to the BBC iPlayer Radio homepage"
I guess I'm left in the dark to why this is...
