I Got Tag'ed This Weekend...
macboy91si
Jan 10, 2009
1,296
Frankfort, KY
So... This store, which I have gotten some other stuff puts a lot of their things on C/L... I have been driving by this place that had this thing in the window. I asked some friends about it, and tried to talk myself out of it. I drove past it some more. Saturday I went in and looked at it... Saturday I bought it...
What could it be?
Hint, there's more to this picture than the coppertone...
Spot On!
Wow Ben, that's amazing...
Yes it is a 1958 Maytag 142...
This is the oldest Maytag I now own, being older I think than the N2L wringer by a few months.
The guy wanted some $$$ for the machine, but I got it for less and got a matched set of Coppertone 1976 model A407's with it. Basically I got this machine, plus 2 still nice Maytags for less than the original asking price.
I spent most of the day on Sunday cleaning and testing the machine, and it works well, very smooth. I need a couple of lightbulbs and there is a slow lower seal leak. This machine was taken out of service working, belonged to an older lady who passed away, all 3 machines came from the same house. Grams used the 142, no dryer, and had an E2LP in there as well. The machine was off of the kitchen in an enclosed sun porch.
I noticed a few replacement parts in the machine, like belts and a newer water valve. The pump is original to the machine is seems or was replaced by another 1958 pump. I was surprised at the differences in this early Newton/Helical machine. The motor, pump tub supprt and the old AMP lid, very cool.
Here is a pic, I think it's in VERY good shape for it's age aside from the lower oil seal. Machine has seen some use, but is not worn out.
-Tim
Control Panel
I was amazed at the condition of the control panel. The chrome was good, and the glass was as well. This is such a beautiful machine all around and so much chrome and lights.
Show Me the Money!
Obligatory money-shot...
The tub is worn a little, not through, but the white has dulled considerable. Also the agitator is well used and unfortunately stuck in for the time being. Some minor rust around some of the lower holes. As you can also see from the pic, the tub cover is NASTY. This will be dealt with. I also found a lot of what appears to be Chex Mix in and around the machine...
PS the tub is not listing, the machine is uneven in the driveway.
Lint Filter
This is (to me) an unusual lint filter. It's copper colored, and very light. I think the entire thing is copper. It's oxidized pretty badly, maybe a vinegar soak with make it look better. I figured it would be stainless like the Highlander's.
In My Belly!
Popped the front panel off to see what I was getting in to and to see how this thing was put together. As you can see, there is a fair bit of oil sling in the cabinet. There is also a bit of oil underneath. I have no way of knowing how old the oil is and how fast it leaks yet. Check out the non-Poly pump and that huge motor spring. Again, she didn't look bad for a 54 year-old machine inside.
Swing It!
The motor setup in this is like none other that I have seen on a Maytag. The motor sits in a cradle, with a pivot attached to the lower arm of it. The cradle pivots on a bearing attached to lower arm and has an adjustable tension spring attached to the pump. It works well and I can't see there being much maintenance involved with this setup as opposed to the motor carriage of the later machines.
Also notice the big, fat 2-speed GE motor...
The Not-So-Poly.. Pump
Another 1st for me, a metal poly-pump. When cleaning I wiped the date of of the pump, but it was made in "Feb 1958" so I can only assume it's original to the machine. Look's exactly like a poly-pump, just metal. There are no issues with the pump.
 The giant spring and hook are the tensioner for the motor arm. I assume that the screw castings on the top were for a suds valve if equipped?
Tops Off To Ya...
Time to clean that tub cover mess. I'm not sure what the mess was, but it was nasty, I got most of it off. The top is raised as normal by two 3/8" screws on each front corner. I though the black porcelain underside was neat as well. Also, while you can't really see it there, the outer tub is speckled. The rubber supply hose was still in good shape as well. I thought the aerator thing was cool as well.
Don't scrub too hard, the filter is supposed to look like that :D
The early 141/142 washers had the 'copper' anodized lint filter, ultra-rare in comparison to the later SS filters. The copper color theme was used only for a few years, and was also used on the timer dial escutcheon. You've got a keeper there.
The original swing mount for the motor turned out to be more trouble prone than the later motor glide. The one's I've seen have weak springs and cannot uniformly provide enough pressure against the belt to properly transfer the torque early in the spin. What I’ve always found intriguing is the poly pumps made all the way till the end can be adapted to the motor spring in case they were used as service replacements for the early Helical trans.
This machine is in really good shape. The trans may need some attention, but in this day in age, any Maytag this old will need new fluid for effective washing. Also amazing is to see an original pump, pre-TBI!
NICE FIND!
Ben
Beautiful
Ben how would you suggest cleaning the screen section? It's a bit rough. I have no intentions right now of pulling the tub or anything, everything on the machine checks out, and I will be installing it in the laundry room soon for light use. I am going to keep an eye on the oil leak.
The machine rolls into spins very strong and the agitation is very brisk, so excess slip or bogging here. This machine is also near silent when spinning. It won't see much use, but I'm also not afraid to tear into it if needed, I'd like for it to be around for a while.
-Tim
Water Fill
This is a neat little thing. A porcelain chute connected to a hose with a copper water pipe feeding it. I'm assuming this is an aerator? The roommate was curious to what it was, he thinks the machine is screaming 1950's design, I am loving all of the little designs on this early machines as I've only really dealt with the 06' series. Even the Highlander is very different.
Home Base
All cleaned up and ready for action!
It cleaned nicely, I was also surprised at how good of condition the baseplate was in, this machine really has no rust on it at all.
Inside of Baseplate
I also cleaned up the inside of the baseplate and inner cabinet of oil which also turned out nice. Again I am surprised at the lack of rust in this machine. Even the dampers were still fresh with lube.
Newer Water Valve
This has been replaced at one point. This is a plastic valve and has newer Maytag logos on it. It has 3 solenoids on it, I think this is a thermostatic valve, how does that work exactly?
This is the only part of the machine that hasn't been water tested, but they all buzz. HOT is fairly quiet, COLD is sort of loud and WARM is loud.
This pic was taken pre-cleanup and you can see some of the oil and mess in the machine here.
Wow, VERY NICE Tim!   Congratulations!   Very purrrdy!
I'm amazed at how small the suspension springs are... TINY, wow!
On the water fill tube, I don't know that it's so much an aerator, as the old / original design of air-gap.
Kevin
P.S.... there is so little rust because of all the OIL that had been flung around, it was protecting it!  (ducks & runs....)
I'd soak the filter in vinegar to soften up the lime deposits, and brush away the lint. Take a look down the detergent shoot in the agitator to see if there are chunks of lint down there. These have the true pump style filter and actually draw more water through the filter than the passive filter on the '67 and later agitators. Use vinegar as well to release the stuck on deposits around the air gap output nozzle. You want this to be nice and clean for an efficient fill!
I wouldn't bat an eye at the washer if it sounds good with a decent load of wash. Keep your ears open for a low pitched groan during the agitation stroke as the agitator shaft bearings may be dry.
I brought home an A702 years ago not far from this washer in condition, with a slight leak. A year later and about 3 dozen loads later, all the oil leaked out and it barely would wash. Keep your eye out for excessive oil leaking.
The new thermostatic water valve is a good sign. Don't worry about the noise from the coils. Usually when there is pressure on the valve they quiet down nicely.
Ben
Temp Switch
This was stuck on HOT when I got it, I removed the switch and attempted to clean and lube it, but the switch, while it does work, it VERY stiff. Is there anything that can be done for this or any replacements available? If not, it will stay on HOT or Warm anyways probably.
Also does this machine automatically do a warm rinse for both WARM and HOT settings?
Also here you can see the date on the pressure switch of "3-58" which corresponds closely to the date that was on the pump.
Inside the AMP lid
The lid was a real treat as well, I have never seen one of these up close let alone the insides. This lid was dry inside and the wiring still soft and corrosion free. In here I found that the machine has a tub light! it's blown, but I was pretty psyched. I ended up jumpering the green and grey wires so the machine would run with the lid up, bypassing the mercury switch. This machine has a separate OOB and lid switch, so I still get OOB protection while watching the wash action. What's better is that the tub light has it's own lid switch so that it lights when the lid is up only. So I can watch the machine without worrying about out of balance AND with a tub light shining on the action. The bulb is blown, going to try the hardware store for a replacement.
Light Bulbs
These are the blown light bulbs, I'm going to try and find suitable replacements at the hardware store. The smaller one is for the timer dial indicator and the longer one is the tub light.
Lights On! / Where's Waldo
Last pic for now, trying the light out after repairing the switch and finding a new bulb.
BEAUTIFUL
Anyone find something else appliance related in the picture?
VERY KEWL Tim!
Isn't this your FIRST machine with a light up or backlit, console / control panel??
YAY for lights!
On the little bulbs, I would think any small, 120V, bayonette type base, bulb with the same wattage, would work.
Kevin
