I need instructions for my DW
Tell me, are these both old style of plates in top rack and glassess in the bottom? Or both the "modern" version with the normal arrangement of plates in the bottom and glasses in the top. Both most likely offer Pots/Pans, Normal, and Light. Rinse & Hold is most likely set at the final rinse with heated ry off or there's a Rinse & Hold cycle between the end of the dry cycle and pots & pans cycle. Pots & Pans is a Wash, Rinse, Main Wash, and two rinses. Normal is Wash, Main Wash, and two rinses. Light/China is Main Wash and two rinses.
There's very little to study. It's all self-explanatory and yes, these are the old Jet-Clean models where you load the plates on the top rack and the glasses below. My only caution to you is to set the dial to the cycle you want before you close the latch to activate the machine. Turning the dial with the latch in the closed position is not so good for the motor and the solenoids. Also, I find that the detergent dispenser tends to clog a lot unless one uses liquid detergent. They're great machines! I use mine daily as a "chef's dishwasher" meaning I put everything into it. I even take out the top rack occasionally to wash big things like garbage cans and the bins from the fridge. A little noisy but cleans well and you got to love that porcelain interior. Very much like the old KitchenAids but not quite as elegant although holds a hell of a lot more.
The machine to Phyllis' left is one like yours ( I don't recommend the soup unless you really know what you're doing):
Doesn't cooking work better with the gas *ON*?
Garbage Soup.............
"Whatever is left on the plate is chopped up and thrown in."
*FAINTS DEAD AWAY*
In times of great poverty or famine is one thing............
That was
my first dishwasher. It handled anything I threw at it, and the few truly burned on things it could not remove, it made it easier to touch up by hand.
However, most things came out totally sparkling on the first wash.
We had ours for nearly 21 years, with only three repairs, two of them fairly minor upper rack issues.
The biggest thing Ma didn't like about it was the noise. It was not a quiet dishwasher. However, even the Heavy cycle was faster than a modern machine.
If your water is in any way hard, get the Jet Dry baskets!
If I could find a portable of this series or of the Jetclean II in good condition, I would be SO tempted.
Lawrence/Maytagbear
Bajaespuma,
I advertised locally to sell it (cheap I may add, first for $50 and then $25 and then for free) but I got no takers. Finally the son of a friend of mine is going to take it to install in his kitchen but so far it is still in my garage. :-)
Gary
Power dry means the heating element is on in addition to the blower. When energy saver is selected only the blower is on during the dry. In either case you can feel the hot air being exhausted from the front of the machine. During the first few minutes of the dry cycle you can also see the steam spewing out the vents.
Gary
The Maytag wc202 videos are up on Youtube
Tests to see what needs to be fixed
This picture was taken up at Hessions WD
Sink is holding a bucket with a Maytag lint filter in it
Tim soaks them first then scrubs them clean and white
I took a look at this and didnot think it was mine
but got to test it since it just needed hooking up..
