I Purchased new AEG Protex Exclusiv Washer
Feb 1, 2015
21
London
Hey all,
I decided to treat myself to a new machine and went with the new AEG Protex Exclusiv weight sensor washer. It arrived a few days ago and I have to say I'm really impressed.It's built like a tank. It replaced a 7KG AEG of about 6 years old. The new washer takes a 9KG load but the drum is significantly bigger than the old one.
It has a weight sensor and as you load the laundry it shows up in increments of .5KG on the display, this affects the wash time. Times so far are great. upto 5KG of laundry takes about 1hr anything less, it drops to 50mins. between 5-9kg takes 1.30-2hr. Pressing the time save button overrides the sensor and reduces the wash time to 50-60 mins depending on temperature selected.
It's absolutely silent on wash/rinse and you could stand right next to it whilst it's spinning at 1600 and whisper and still hear yourself. Seems to use a decent amount of water. 2 rinses as standard but you can add upto 5 extra rinses. The water spray starts a soon as the water starts to enter the machine spraying the clothes as the machine continues to fill.
I'm really pleased with it. So much so i've ordered the matching heat pump dryer which will be delivered tomorrow. Both came with a 5 year parts and labour warranty. I'll get some shots of the dryer up when it comes and some videos.
Any questions please ask
These machines do look stunning. It's such a shame about the welded outer tub, though, which is a deal breaker as far as I'm concerned.
Any chance of uploading a video of the final spin cycle?
These things do look very good, but..
...I don't think steam programmes are really needed, or are they?
I feel they should get rid of those, and add two extra programmes, Jeans, Curtains, Shirts, sports shoes etc etc.
I cannot wait to see a few videos from you though, and are you enjoying these machines? How fussy is it when it comes to balancing, and how many rinses do you get on the Allergy cycle as standard?
Splittub - I'll get a video of the final Spin soon. Using the weight sensor, the length of the final spin seems to vary depending on how much you load into the machine. If there's not a lot in there it does a 10 second burst of around 1000, tumbles without the pump on, then distributes, ramps straight upto 1600 and holds it for 3 mins then finishes. If it's a full load, it does a short burst at 1000, tumbles, distributes then hits around 1200 for 2-3 mins, then heads upto 1600 for 3 mins. Either way I'm really pleased how dry things are coming out. It tumbles at the end of the spin for 1 min and then every now and then after the cycle has ended for up to 18 hours or until you open the door. If you select the short wash time it cancels the tumbles and as soon as it coasts down from 1600 and stops the door unlocks straight away
ChesterMikeuk - The thick top is actually a stacking device I bought for the dryer to sit ontop. It has a bench you can pull out I guess for unloading and a very thick rim so the dryer sits securely.
Glenfieldmathk1 - I agree re the steam cycles. I very much doubt these will ever be used, unless a shirt gets over dried and hard to Iron. Have had absolutely no problems with distribution yet. Including washing 1 bath sheet, one hand towel and three face clothes together. It vibrated a little more, but went straight into spin and the drum doesn't seem to move at all. Every other load has been almost silent to the point I usually miss the final spin and have heard the door interlock click off and the cycle end bleeping starts.
Lovely machine here, looks great in the pics. The Protex drum looks good too, I nickname it the plughole drum as that's what it looks like lol. My Nana has recently brought an AEG too, the more basic L6027FL, I've been down to see her lately and I'm very happy with it.
I look forward to any YouTube vids of it, I know there's a few similar models already up lol :)
Steve
Very nice! I saw these at Domayne the other day and was rather impressed.
The spin sequence you describe for a heavier load is the same basic sequence that my 6 year old Zanussi made Westinghouse has.
I really like the look of the machine. Seen a few vids online of one in use and love how silent they are.
It seems that Electrolux products all seem to adjust the times of the washes with the amount put in. My older 2002 AEG used to adapt the rinse sequence and times by the amount of water absorbed. The same thing out current Zanussi Flexi Dose model does. If the load isn't absorbant, it makes a short cut during the wash but if absorbant then it takes ages to wash. The rinse tumble speeds vary, sometimes slow, sometimes normal, as well as final spin if load is not perfectly balanced.
My parents have the L75470 washer!
I wanted them to get another with a jet like the AEG we had previous to it but funds wouldn't allow it!
I like the sensing how it can dramatically reduce cycle length. The spin is extremely similar to my lg f1402fds6!
I've taken a pic but for some reason my new iPhone won't let me upload it!
Darren
Hey Ronhic, - Ah, I miss Domayne. How much are they selling for back home in Aus? I'm really impressed. Really well built and so quiet. Only annoying this is the smoked glass screen on the door. It seems every load has different wash lengths, drum speed etc. The dryer arrived Friday and again a fantastic machine and very quiet for a dryer. I'll post some pics of it.
Darren - how are you? Are your folks pleased with there AEG?
I'm surprised at how quickly it dries. I had read reports that heat pump dryers take longer to dry, so so far so good. About 35 mins to dry a kingsize quilt cover, two pillowslips and a fitted sheet. It doesn't seem to get very hot inside, so it must use a lot of airflow to dry. My mums condenser dryer if opened during the cycle steams up the kitchen and the clothes a really hot to touch.
Also, not sure if I just haven't paid much attention to dyer drums but it's only the side of the drum that turns, not the back of the drum - is that normal?
Protex
Congratulations Steve, looks great stacked, the thick stacking tray really works well...
The Heat Pump dryer works very differently from condenser models, it doesnt use heat, just builds up residual heat and the programme finishes...
The ones I`ve used are much quicker in time to complete the drying programme than condensers, the heat pump works by sucking the moisture out of the clothes via the pump, as the air is re-circulated the air takes on temperature, they seem to work the opposite to other dryers ie, they start cold and the air warms towards the end of the cycle...
You may have to alter your way of drying, I used a lot of mixed cotton duvets, sheets etc...after the wash-ins or visitors I could have 6+ king size bed sets to wash & dry, with the MaytAsko I would spin them all at max extract (1600) then pop them in the condenser dryer for 20 mins to de-crease & dry....
So did the same with the heat pump, only thing was there was no heat to drop the creases and so little moisture they where dry in little time BUT with loads of creases....I ended up spinning at a much lower spin to prevent excess creasing, leaving them wetter but it gave the Heat Pump a chance to warm the air up and it was still cheaper to run than a normal condenser!!
Let us know how you get on!!
Thanks for the info mike. I have noticed the dryer working very differently to what I've been used to. Clothes i.e. singlets, t.shirts etc all come out without creases. I have two 1200 thread count Sheridan quiet covers than come out great, with no creases, where as cotton duvets have come out very creased. I shall spin dry these at a lower speed next time and see if that makes a difference.
Is the drum on your heat pump dryer a sealed drum and the whole drum rotates? I'm really thrown but just the sides of the drum in the AEG that rotate and not the back.
The wool cycle is interesting and like the Hotpoint Wool wash, the drum turns at a much higher speed, pinning the clothes to the drum throughout the drying cycle.
Dryer Drum
The Zug Heat Pump dryer has a normal rotating drum and back panel, although it has a solid door so you wouldnt be able to tell working!!
The stationary back panel is used on US dryers, as everything seems to be on the change at the moment not sure if any other dryers work the same here...
Would you take a pic of both drum door filter and the heat Pump filters down below please?? Do you have the condensate water pumped to a drain??
Steve are you in Sydney or from Sydney and in an other part of Aus??
I'm from Sydney but live in London now. If you are down this way you are more than welcome to come and have a look at the machines in action.
Pic 1, front filter
Protex
Lol, I did wonder, just assumed from your profile it was us, but then noticed the 13amp Brit plug and noted that AEG Aus didnt have these models on their site...
Similar style filter set up as Zug, they do collect very fine dust well, I do find you need to keep all the area around the dryer and intakes vacuum cleaned, also if any residues from powder / softener is left in clothes it get stuck on that Heat Pump filter...
Is there no black sponge filter on the Heat Pump filter??, it looks like it is just another fine nylon almost see-thru filter??
