This is gonna be a long one
So, played around a bit.
First, setup:
I deselected ALL audible signals, hooked it up to my WiFi, activated the cool down, set the Water Plus so it only adds a rinse.
Service cycle and programming mode is entered by having the machine on, the door open, then holding Start/Pause, closing the door, waiting till the flashing ends, button presses as on previous models, holding till solid and releasing immediatley.
Just activated the balance sensor so far (default for out of balance sensing was "tacho" and I switched it to "tacho + sensor"), but I'll try to see what changing the Recirc settings do (there is a "Recirc without fault display", "on" and "off" option with the first one being my default).
Could up temperatures as well and deactivate the guided energy usage, but I'm happy with th results in the default mode so far.
Actually, I ran the first cyclce before leaving and watched the initial stages.
Small load of kitchen towel stuff.
Some powdered detergent on Cottons 60C SingleWash with "Stains" selected as option.
Time was 1:29h and the mainwash and results were amazing and usage was like 5l per fill.
Next, sunday after returning I ran my usual large loads of a pair of jeans, 4 pairs of sweat pants and 4 sweat jackets on a Cottons 40C cycle with "Extra Dellicate" selected.
The option overrid the option for a PowerWash 2.0 cycle, but load size would have ment a normal wash cycle anyway.
Fun fact there: If it fills via the door first, it is a normal cycle; if the detergent dispenser is flushed immediatley, it uses a PW2.0 cycle or a modification of that (SingleWash).
The load was about what would be "proper loading ettiquette" for a drum this size, so not tightly packed.
Saturation was done in less then 5min.
Then a short heating burst was carried out before doing the 2 PowerWash Spin and Spray cycles.
Then heating commenced and heated to target temp in a 2 stage pattern with a short pause inbetween.
The Extra Delicate option basicly steps down the main wash rhythm one notch (Rhythm "A" "Intensive" turns into "B" "Normal") and maybe alters the spin (can't say yet, haven't seen a true final spin on cottons yet).
Interim spins were pretty fuzzles and thorough.
Rinses were all the same, all aboout 5 min long, all the same water usage.
Final usage was 0.8kWh and 72 or 74l of water.
Final spin was interesting though.
It did 2 bursts with a long anti crease after the second burst.
It started the final spin sequence at 27min left, started it final burst at 16min or so left.
That final spin stepped up to over a few minutes, then hit 1600rpm for the first time at 12min left, held it for one minute, slowed down considerably (maybe 800rpm) for a minute, and repeated that cycling 2 more times.
Did a LONG fluff tumble as well (like 7min) so I suspect the Extra Delicate changed that as well.
Results were nice.
Ran a New Items with SingleWash at 40 as well.
Load was 3 new white TShirts with some liquid detergent for whites.
Wash action was the handwash rhythm for some reason and cycle was only 30min total, so not gonna use that again.
Over night I ran an Eco 60C cottons cycle with the Aqua fabric softner cap and a half load of a small set of bedding and 2 towels I used during my weekend away.
Can't say much about that except super efficent, everything felt nicedry and clean and that I don't really like Mieles fabric softener smell.
Monday I ran my first observed PowerWash 2.0 load.
Load was my micofibre bath items (2 bath mats of different size, my supper plushy bathrobe and a towel I have made of the same material as the bathrobe).
Cycle was Easy Care 60C with Water Plus selected. Detergent some powdered colors stuff.
I used this cycle specificly to check one of my hopes/sorrows about these machines:
The manual states that selecting Water Plus will cancel PW2.0 and run a normal cycle instead.
I was fearing that programming the Water Plus button to add a rinse would do that still.
I didn't spend that much money to waste water and energy needlessly.
Luckily, in that specific configuration, PW2.0 is executed just normal.
Machine filled with 2l of water first, did its first spin with the short sense burst up.
Refilled with another 2l of water, then did 4 or 5 more spin bursts with the spray on.
Load looked damp everywhere, but not wet.
Machine drained, filled with another 2l and started heating.
So in total, it had to heat 6l of water to 60C.
Machine heated in pulses for a good 30min and the door got pretty warm.
Main Wash ran for another 40min or so after heating ended without adding more water.
During those 40min it regularly tried to recirculate water, but there just wasn't enough in the tub.
Until now the machine used a pretty quick rhythm. Not the intensive, pretty much just the steam smoothing rhythm.
At basicly 1h left flat it added more water for the dilution part of the wash.
After that fill finsihed (filled once, then added some again) there was a usage of 14l, everything was dripping wet and the water level was low but enough.
Agitated for like 8min or so on the "B" rhythm, then inexplicably went down to the delicate rhythm for the last 10min.
Drain, proper high interim spins and 3 rinses and a 10min final spin sequence later, I had perfectly clean, perfectly rinsed and perfectly fluffy laundy.
And it only used 0.5kWh! (But 70 odd liters of water due to the high absorbtion and the additional rinse.)
Next I ran some seat cushins through a pillows cycle.
Couldn't watch that, but results were as expected.
The covers for those cushions I ran through a box standard Delicates 40C cycle which appeared to try to run as a PW2.0 cycle.
Which is weired, as only the most recent machines list Delicates as a PW2.0 cycle in their manuals.
Couldn't sense the load though as I overdosed on the detergent compared to the 2l of water it tried to use to saturate the load which caused a huge suds lock during that first spin and spray which canceld any further sensing and just ran a normal but thorough Delicates 40C cycle which still only used like 50l and 0.5kWh.
Ran some other rubber backed bath mats through a Sports cycle which (didn't watch much but some) appeared to be somewhat simmilar to the delicate cycle, just with lower water levels.
Today I ran an Outdoor and Wterproofing cycle which both performed as expected.
Waterproofing is one of the few cycles that do NOT light the PowerWash icon as it's only a glorified heated rinse.
Same goes for Rinse and the spin only cycle.
Currently runnign a Curtains cycle with Water Plus, Prewash and Preironing.
Preironing adds 30min on any cycle I saw.
Cycle used pretty low water levels but decent agitation.
Let's see what the results of the ironing stage are.
Overall this is just such a refined version of what I was used from the Novotronic and Softtronic ranges.
Spins are still no fuzz, but it certainly knows when it is better to just redistribute quickly.
Spins are so much better in terms of layout. No signs of water or suds locking, ever.
I so missed the high tumbling arcs that I somehow only associate with Miele.
Laundry finaly TUMBLES again, not just "tumbles".
And even though this thing is efficent, it isn't stingy with water usage. It knows when to use more water.
But it more so knows HOW to use water.
Like, not just DUMPING more water in during refills, but sipping liter by liter.
It's just such a grown up, still verry simple, yet so sofisticated machine so far.
Only thing: The remote control features SUCKS to set up and SUCKS to programm cycles.
It would just change options on me.
But it nicely reports all the most importatnt stats.
Will be running some more stuff during this week as my days allow.
Ask any questions you would like to ask, I'll post some pictures once I have my phone in my hands.
First, setup:
Results were nice.
