Reply #33
Hi John, unfortunately the timer is pretty much done for since I’ve literally tried everything you can think of. Tweaked the little tabs on the contacts, worked somewhat but seems to not have done much. Invested at least 40 to 60 hours into it, still haven’t gotten anywhere close to getting it functional, even on the regular cycle. The cams might possibly be worn down which can be causing it to not work as intended.
Unfortunately, I don’t have anything else left at my disposal other than to transplant these consoles on that a friend in Colorado sent (paid for the shipping). It may change the appearance, but the mechanism is going to stay the same, only thing that will be different is the programming since it has a 4 minute drain as opposed to the 2 minute drain, won’t have issues with a water lock or suds lock.
Quite reluctant to do this, but sometimes you have to do what you have to do to keep things running even if it requires a complete retrofit.
If you are wondering, going to paint the side panels with some turquoise paint that’s actually quite close to the turquoise on the machine, just a shade or two lighter.
I’ll create a dedicated to resurrecting those machines back to life sometime within the next couple of months.
If you are wondering, the dial faces were removed for shipping and are getting sent with other parts that were pulled off (automatic dispensers, inlet valve, wiring harness for the washer, other miscellaneous odds and ends).
