IFA 2016 Thread
Even though I'm not a fan of bagless vacuums, it looks awesome.
AEG launched a new website design as well; some of their 7 and 8 series washers and dryers are up already, the series 9 ones aren't. However, a short instruction manual is avaible which shows the salt tank for the water softner to be integrated into the detergent drawer, which as a result only has a main wash and a softner compartment. Prewash will still be avaible via an option button though.
Vestel / Sharp / Servis
The latest laundry featuring "Pyrojet" in-line heating for quicker heating and energy saving !!
"Pyrojet technology is the revolutinary unique feature of Vestel washing machines which enables higher water temperature in a shorter time by heating the water during the circulation process. A+++ -70% energy rating for 8kg can be achieved by this technology."
Beko from Arcelik
The AquaWave® technology is inspired by the natural movement of waves: a specially designed drum pattern gently carries the faundry through the water, moving it smoothly around.
Families who attach high priority to gentle, efficient washing are weil catered for with the new XL capacity washing machines WY104764MW and WY114764MW. Both models are fitted with an extra-large AquaWave® drum in standard depth, which means the WY104764MW holds ten kilograms,and the WY114764MW impressive eleven kilograms. The AquaWave® technology helps to make your favourite garments last langer: the specialdrum and door glass designs move the laundry smoothly, so that the materials are handled gently and cleaned deeply. Thanks to incorporation of the long-lived ProSmart™ Inverter Motor, the washing machines are 20 per cent more economical than other appliances in energy efficiency class A+++. For different materials and needs, users can choose between 16 different washing programmes, including numerous special programmes like the CooiCiean™ cold-wash programme for cotton materials, a SteamTherapy™ programme for delivering easy-iron laundry, and a woolmark certified wool programme. Users also have a self-cleaning programme available for the drum.
Now I want an Avantgarde!
It features the same avantgarde display, but has Home connect technology, which allows you to choose from 4 ASR stains on each programme, and also has a further programmes selection (which presumably allows for programmes to be chosen from the app).
Dryer features connectivity too :)
Beko from Arcelik
Do you have any idea if they have anything updated regarding their way of washing example they added a load recognition or they are still same?
The Beko technologies
Aren't that new really. My 12kg machine has Aquawave drum , Proinverter motor and a steam function and I bought it 9 months ago. Some of the features on the 8kg machine have been around on that range of Beko's for a while to. Hygiene 20 is relatively new.
Curious About the Candy
Chestermikeuk what is Innovation 70... I mean why 70? There's not much info about that Candy... I only found an article so far which is all in Italian (link below).
I guess all companies splash out with innovation on these kinds of exhibitions but really and truly all the technology mentioned there was already available in Candy group machines before this very model... the load recognition especially was already part of every single machine of theirs since the beginning of the millennium even in most of their BOL range. They should mention that their machines have water pressure recognition as well as almost every other non-Hoover/Candy machine I've tried in a low water pressure environment has been going into panic mode... well... maybe they'll say that at the next IFA ;)
http://www.dday.it/redazione/20893/benvenuta-bianca-la-lavatrice-iper-connessa-di-candy
Hoover Version of the Candy...
Here's the Hoover version of the Candy seen above which will boast a new component called TED (Textile Expert Detector), namely a scanner that recognises the fabrics inserted in the drum.
