IFA 2018
henene4
Feb 6, 2013
4,324
Heidenheim a.d. Brenz (Germany)
https://www.miele.de/forms2/de/sa/manuals-125.aspx?mNo=11011700&asDownload=1
Red through their press releases and found this after some searching, a spiritual succesor to the Touchtronic: WCR 890/870/860.
Going to A+++ -50% in under 3h with a new iteration of PowerWash 2.0.
I'll keep searching their databases for all the other new stuff.
[this post was last edited: 7/18/2018-09:54]
Dryers
The lower end, 1 line display dryers matching the already released updated washers are the TCJ690/680 (which appear to have gained a bedding cycle) and simmilar numbers (searching for 0WP and just checking which letter combinations seem familiar and which not works):
https://www.miele.de/forms2/de/sa/manuals-125.aspx?mNo=10966940&asDownload=1
It actually appears that a lot of new dryer models will appear, all featuring bedding cycles.
Can't find a touch display dryer though.
The new TOL will be the WWV980 "Passion":
https://www.miele.de/forms2/de/sa/manuals-125.aspx?mNo=11011680&asDownload=1
(For washers I search for PWash or TDos and do the same comparing).
Further there is an updated SpeedCare range including a SpeedCare dryer.
AEG
Will be launching automatic dosing in their FL washers from 8000 series all the way down to the 6000 series, but not the 9000 series, leading me to belive it's a simmilar setup to BSH iDos.
Their 9000 series dryer will get more showing off. It uses a "moisture scanner" what ever that means (perhaps thermal imaging or air humidity sensor?).
Their TOL ComfortLift DW will get a new user interface using some sort of slider.
Their hoobs will get SenseFry (sensor guided frying).
And their fridges get redone.
QuickPowerWash
The new W1 updated models have gone back to one rinse in the QuickPowerWash with no water plus option. That's a shame. I have a WMR861WPS which does two rinses in QPW.
The new touchscreen Miele W1's look promising, I wonder if they'll have a colour display like on their ovens and that it'll be larger as well. The only drawbacks of the current flagship model is that the screen is a bit small and also they haven't been adventurous enough with it. :).
That's better Miele, those touchscreen W1's look way better than before, I wonder what that clock thing at the top of the machine is for? :)
Wish they had brought back
the orange button to open the door.
Not a fan of having to push start/stop to get it to unlock.
I am guessing the clock on top is to show how long the quickpower wash cycle is. If the touch screen wasn't so minuscule then....
Passion? Ecstasy, Delight, Rapture and Orgasm too much?
Not a fan of Miele's current direction, why couldn't they just keep the classic-looking machines in production? I believe the classic design is still around in the form of the Little Giant series...
I browsed Google Patents. What I read about was an updated cup rest, auto-dispensing of a pourable detergent (powder, liquid?) and hot-air drying. These were the latest entries.
