Thanks!
Darren...I don't know a lot about the temperature! The machine cen be hooked up with hot-cold fill (there are two separate inlet valves) or with a Y with cold fill only.
In the first case the machine will work (I suppose, cause I've not checked it yet!) as any hot-cold fill washing machine...so HOT(hot only by the water heater temp settings), COLD (tap cold, water line temp), WARM (both inlet valves are opend)
In second case... well the machine is provided with two onboard heating element (1300W each) and a thermostate with 5 contact so...one will be the neutral and the other will be for 4 temperature setting...but honestly I don't know :-?
Under the cabinet lid you find something about the 8 cycles available but the descriptions say only about the items you can wash with each cycle (bedlinenes, bathlinens, shirts, pants, ecc)...no information about temeprature and wash or spin speed.
The motor nominal speed is 500rpm...but I think it reaches 600 rpm...
BYE!
Diomede
