incoming COLD water temps.....
yogitunes
Apr 21, 2009
13,520
New Jersey
well here on the East Coast, at least in South Jersey, were currently hitting single digit temps from a cold front....
and figuring this would be a good time to test the incoming tap supply's temp....
I expected lower, but got a temp reading of 40 degrees Fahrenheit...from city water, can't imagine what well temps would be...
even with super hot water, I had to increase the hot side beyond my center/normal position while taking a shower...
just curious, what are your incoming temps showing?
Had a shower, left the water running after I finished to check the tankless display.  Input reported 67°F, can't say how accurate is it. Well water, the pressure tank is in my garage, protected from direct weather.  Supply line from the pump is underground except where it comes up through the wall.  Current outdoor temp 71°F.  Weather predicts 31°F for a couple hours in the morn after the next blast blows in tonight.
