Increasing fill time on timed fill dishwasher
adam-aussie-vac
Dec 14, 2017
1,104
Canberra ACT
Hey guys so my little Israeli made dishwasher does not take in enough water, is there anything I can do to Have it to fill up at the bottom of the dishwasher more? I thought about using a delay timer on the wires going into the solenoid valve so that way when It calls for water it will add a bit more water on top of the normal amount the dishwasher normally Put into the tank
What is the  inflow like?
If it is filling slow, your inlet valve strainer may be a bit blocked, or the rubbers in the solenoids may be getting old and hard. (very common.)
I'd try replacing the solenoid with a known-good one.
Is it definitely timed fill? It looks too new for such old-fashioned technology. Is there no pressure switch?
