Inducted into Induction
For years, chefs and maitre'ds have done side cart work using a portable burner called a Rouchade. (sossibly spelled wrong)Most are butane fired.
About 10 years ago portable induction burners became very popular for demo and offsite food preparation in the industry.
Some more affordable units came out of Asia and sold for about $250.00
In order for any pan to work with induction cookery it must be able to attract a magnet. The heat is generated from magnetic energy.
I have not seen or had experience with metal surfaced induction cooktops, but would think cermaic or glass would stand up tolong term scrubbing with out showing as much wear as painted metal.
Induction cooking is amazing, fast and a little quirky. Once you remember the heat values with the cooktop you are using you simply dial the number, like a thermostat to get precise levels of boiling, searing etc. A warped pan can produce a fun but scary light show and if you forget to add food to the pan or it cooks dry and over heats, the unit shuts down. Personally, I still prefer a conventional burner, electric, for slow and tender simmering.
After all, isn't slow and tender good?
Kelly
