pierreandreply4
hello to all aw members as you know my duet set washer and dryers days are number as this summer the set i have will be 10 years old and i think the dryer is already on its las lengh so for my next set i am considering buying the ge topload washer with the power rinse option do not SUGGEST A FRONT LOAD WASHER i do not went to buy a front load washer i did not like the duet washer since the first day it was delivered back in 2004 i am more the top load kind since i only wash using cold water so for me having a water heater in a washer is not needed since the only cycle i use are normal perm press for shirt and sometime the gentle cycle and also the advantage of having a top load washer for me is if i have to soak something all night i will be able to do so also included is a pic of the set all info welcome thank you and i repeat do not suggest me a front load washer as a front load do not fit my needs.
http://www1.thebrick.com/brickb2c/jsp/catalog/product.jsp?id=GE2800PKG&navAction=jump&navCount=3#
