rolls_rapide
Does anyone else get irritated by the way that modern machines operate?
For example, my latest machine, a Panasonic front loader, when on the speed cycles, will not do the final de-plastering tumble after the final spin. It spins, stops abruptly, door unlocks, end.
It will do the tumble on a normal Cottons wash - but that takes anywhere between 2 and 3 hours.
The pumped jet spray operates in short bursts, but seems to be in a certain temperature range. For example, recirculating 90 deg C wash water it will not do. The old Zanussi did.
The fuzzy logic Autocare program is a nice idea, by poorly executed. The machine decides itself which spin speed to select - and no final tumble either.
