pinkpower4
Save energy but not at the cost of making the products unfit
I tried to save energy in the ways I can by being careful about the amount of water used for a bath, changing out the guts in the toilet to use more or less water depending on the situation, using fans to distribute air better in the summer vs. turning A/C up, wearing a jacket/sweater around the house in the winter, etc. I drive a vehicle that gets good gas mileage and not more than what I *need*.
However, these DOE regulations have made many products unfit for a particular purpose Unless you know what to buy, you are likely to end up (for example) with one of the HE washers that doesn't use enough water or warm enough to clean clothes. They are cheaper built too. The result? More time, energy, chemicals, additional water, etc. is used. They end up in the landfill much quicker. Though some have an easier to repair design (vmw), the reality is most people won't. The cost of repair and labor is often half or more of what they paid.
We went to to those flow saving faucets at work. Water barely trickles out. Thank goodness, this was fixed. Hand washing is key in trying to prevent the spread of COVID. The toilets used barely any water to flush. The result? Some very unpleasant surprises and lots more flushes to get the stuff to go down.
When I replaced my dishwasher almost ten years ago, I could not figure out why the new one didn't work. We were practically washing dishes before putting them in the dishwasher. You guessed it, lots more water than we had used in the past. The energy saving design was an issue but so was the change in the detergent. I now get better results with that same dishwasher using Cascade Boil out.
I am old enough to remember less is more. The old basic mechanical washers with transmissions and simple dishwashers just worked. Bring them back! Where you can save is to use something like a spin dryer. Seriously, I have noticed a difference in my electric bill from that ONE change. Clothes are dried in less than half the time, and line drying is much quicker which means I can take advantage of that option more too.
