Introducing The Lustron Home
We have 3 Lustron homes in our area, they're in Wausau, Rothschild, and Mosinee. I have to agree with Neptuneguy, very utilitarian, and sterile looking.
For some reason it reminds me of that Twilight Zone episode, where Roddy McDowell becomes a zoo exhibit on another planet... I think it's because of Launderess's first link in this thread -- there's not a single open or undraped window in the entire set of drawings. Extremely creepy IMO.
http://strandlund.tripod.com/index-9.html
boy, those houses look like a lot of fun. I'm not sure if I'd be into it in the long run, but I wouldn't mind trying it for a few months or so, just to see what it was like.
Laundress, out here in Seattle, we used to have quite a few neighborhoods where there were small houses on big lots. They have pretty much disappeared as people have inbuilt, and the zoning has changed to allow for what we call "unit lot subdivisions" (numerous tiny homes crammed onto those former large lots). We used to have quite a few "truck farmers", so maybe that was the reason they were set up that way.
Probably because the photos were "sets" or complete models at the factory or some place else where outside views weren't appealing. These houses were nothing mopre than a cmplete house vs. a Youngstown Kitchen, or something similar, that was all metal--not a speck of wood insight. That's just as cold, but remember, this was kind of "high fashion" and affordable at the time. Why do ya have to be so negative all the time Jeff!!!!
I remember seeing all-metal kitchen sink/counters in the 50's. And even back then a lot of them started to look tacky, with chips and scoured areas. The cheaper ones had just painted cabinets, I guess, not enamel, and the paint would wear through round the door/drawer pulls etc. Quite often the lower cabinet doors would be bent and tweaked so they wouldn't close right. Those old worn kitchen sets would creep me out a bit, as well.
I would guess that re-wiring a Lustron home would be a real challenge. And those "permanent plastic seals" between the panels... as we all know now, plastic is anything but permanent. Probably embrittled over time and shrank, resulting in air leaks.
I do like the idea of a porcelain enamel roof, though. Although I've heard that firefighters tend not to like metal roofing, as it can be difficult to chop through in case of an attic fire. I find it amazing that in this day and age, the most common roofing material is nothing more than a short-lived fiberglass mat impregnated with tar and sprinkled with aquarium gravel. You'd think that modern science could come up with a reasonably priced synthetic substitute for the composite roofing shingle that would really last 40+ years without weighing a ton and emitting a ton of pollutants.
And I guess hanging a flat panel TV off one of those walls would be near impossible without a diamond tipped drill and a lot of patience.
Firemen chopping thru roofs is becoming a thing of the past.Firefighters are now using chain saws with carbide teeth chains.These will cut thru most roofing materials except the metal.for metal roofs they can use a Partner gas circular saw with a carbide block grit blade.These will cut thru all types of wood and metals-even some masonery.Also some "Battle-Bot" sport fighter robots can be equipped with these blades.The blades are expensive-about$300 for a 14" size-most Partner saws use that size blade.also these are available for Partner "ring" saws.They are much like the circular saw but only the outer portion of the blade turns-the blade iteself looks like a large ring with a sprockets on the inside.On the Circular frame is a sprocket on it turned by the saws motor.These can be gas,Hydraulic,or electric.The advantge of the ring saw is it can cut about the full depth of it blade carrier diameter-instead of less than half of the blade diameter for traditional circular saws.I am afraid the Lustron roof would yeild quite easily to a Partner saw with the carbide block edge blade.
for drilling into the Lustron wall-use the solid carbide drill bits a gunsmith would use to drill thru hardened rifle receivers for scope and sight mounting.These drills are expensive-but for the job-say mounting a TV-would be worth it.
Lustrons:
The Lustron was actually a pretty good house for its time. The Museum of Modern Art had one in an exhibit of prefab architecture last year, which we covered in Modernism Magazine.
The major thing about a Lustron was that it was an exceptionally well-built house in an era when a lot of so-so construction was going on. The years after WWII were a time when housing was scarce and a time when many new families competed for what was available. Builders didn't have to put much effort into what they sold, and by and large, they didn't. By the late '40s, buyers were looking for quality, and two major efforts were made to give it to them. One was the LOOK House, sponsored by the magazine of the same name. The LOOK House was a standardised-plan house that builders meeting certain standards could build under licence and offer under the LOOK name. It was completely conventional in materials and construction.
The other choice, of course, was the Lustron. Consumer Reports checked out both the Lustron and the LOOK House, and liked the Lustron better. The Lustron was made of lower-maintenance materials, had more durable finishes, and was essentially fireproof. There was an incredible amount of closet and storage space in a Lustron, given its limited square footage.
As built, Lustrons were more attractive than most of them are today. The porcelain finish was originally semi-gloss inside, with a less shiny quality than is now the case; time and cleaning have worn the flatting agent off the surface. Luston bathrooms were very up-to-date in their day, with all-porcelain walls.
Lustron's recommendation for hanging pictures was to drive small brads into the plastic strips between wall panels. Photos of model Lustrons taken when the houses were new show that the houses were very attractive and livable in a late-1940s way. Floors were linoleum or asphalt-rubber tile, which wasn't that uncommon back then, even in living rooms.
The major problem with Lustrons today are rust, neglect and owner attitudes. Rust can occur wherever the porcelain chips or flakes away; the problem is exacerbated by the fact that Lustron used a lower-quality steel than is recommended for porcelain coating today. Neglect and remuddling are big problems; a lot of people have tried to make a Lustron into a more conventional house, and trust me, it does not work. Everything about a Lustron is different from conventional construction, and there is very little you can pick up at Home Depot to work on it with. The attitude of the owner determines if they'll be happy with a Lustron or not - you have to take a Lustron on its own metallic terms, not spend your time wishing it was something it isn't. Some people never adjust - one Atlanta Lustron owner famously sniffed, "Like livin' in a lunchbox."
There is a Lustron homeowners' discussion group on YahooGroups, and there are plenty of people seeking these quirky houses out and restoring them, or even dismantling them and moving them to save them from McMansion developers. Because of their all-steel construction, they're also favoured by allergy sufferers; they're very easy to keep clean.
If you want to get a sense of what living in a Lustron was like at the time the houses were new, there is a great page on one of the Lustron websites. On it, a guy who bought one new has contributed his family's photos that show it throughout most of the 1950s. I was around in those years, and I can tell you - nothing about that house would have seemed all that weird at the time. I've included a link to the page below.
Here's a photo of a Lustron's living room decorated as a model home sometime around '48 or '49:
http://www.lustronconnection.org/html/interiors/davenport_IA.html
One issue I could see with the Lustron type home is ventilation.
A typical wood frame home of the era was quite leaky and porous. Water vapor released inside the home and from the earth below could easily migrate out through the wood, plaster, etc.
An all steel home would probably retain far more moisture inside than a wood equivalent. Modern homes are fairly well sealed so that ventilation has become an issue for the most energy efficient models - which require passive or active heat exchanger ventilation to maintain indoor air quality. Back in the Lustron's time, I would imagine that failing to open a bathroom or kitchen window, or run an exhaust fan, would result in a rather clammy condition indoors.
Just guessing, mind you. I've never stepped inside a Lustron - but I have looked inside all metal lunchboxes!
Suds:
Lustrons came with a through-the-wall mounted Nutone fan in the kitchen standard. That would have taken care of a lot of moisture buildup problems right there; kitchens are where a lot of moisture originates.
And even though Lustrons were much tighter than most "stick-built" houses of the time, they still weren't tight by today's standards. Specifically, the metal-framed windows were single-pane, with no weatherstripping where sash-to-frame contact occurred.
People who own Lustrons today generally have to do some retrofitting to make their windows perform a little better; those magnetic inside-mount storm windows are the best fix at the moment. Some owners replace their windows, but that is considered detrimental to the house's historic value, and it never looks right to anyone who knows Lustrons.
Magnetic inside mount storm windows
Tell me more. I think I'd like some for my home.
But it has aluminum frame windows... did the Lustrons have steel frame or aluminum frame windows?
Magnetic Storms:
Don't actually mount to your windows; they attach to the window trim inside the house. In a Lustron, all of that is steel, so the magnetic storms just cling to the frame on their own.
For most houses, a metal strip is attached to the wooden window trim, and the storm attached to that. What you buy is the metal strips and magnetic strips that have pressure-sensitive adhesive backing. You then buy Plexiglas (Perspex to our friends on the other side of the pond), cut to fit each window, plus some overlap. The magnetic strips are then adhered to the Plexiglas. Mounting the storm is a simple matter of allowing the magnetic strips on the storm panel to grab the metal strips on the window frame. Again, in a Lustron, there's no need for the metal strips, since the area around the inside of the window is already steel.
Here's a link to a company called Magnetite offering the setup; there are several others, so Googling "magnetic storm windows" will turn up alternatives:
http://www.magnetite.com/how.html
Oh, heck, I could cobble up those on my own. I can get the Plexiglas and magnetic strips at the local TAP Plastics shop. The steel strips could be just about anything - although I'd probably prefer magnetic stainless 'cause they wouldn't rust out quite as quickly as plain steel.
