vacbear58
And my twopence worth
Pete
Here in the UK laminate is also popular in living areas at least. It can be cheap to buy, is fairly simple to install and is hardwearing.
There are several considerations, some of which are mentioned above, such as allergies & pets, although we seemed to manage with both here for many years. But there are some other points:
Do you own your home? If not then the lowest cost option may be appropriate given that you may be obliged to move on and leave it behind at some point.
Is it a light room or dark? If light then the options are many but if quite dark (like my living room) then, in order to mazimise natural light, you may go for a light coloured flooring of whatever kind.
Is there a "traffic" pathway through your living room from one part of the house to the other. If so then laminate or hardwood may be the best option as it will be much easier to keep clean, even with the variety of efficient carpet shampooers there are these days.
Is it more of a day or evening room. If evening then you may choose carpet for a cosier feeling, where it may not be so important.
Or be like me and have both, laminate with an area rug in the seating area. I have the problem that I have a fairly small and dark living room that has the main traffic flow through it, so mine is laminated. Athough the laminate is light to mid brown I still think it makes the room a bit dark. The area rug is plain, in a mid yellow colour. I have no pets or breathing allergies so if I could, after 15 yrs or so of laminate, I would have carpet as I use the room mostly at night (I am at work during the day) as it is cosier. When the carpet gets grubby or spotted my shampooer brings it up like new with little effort. And if you collect upright vacuums, is is an oppertunity to use them more, one which I rather miss.
Al
Pete
Al
