Is the Thermostat on Home Deep Fryers Adjustable?
gredmondson
Bronze Member
Nov 7, 2007
254
San Francisco, California 94117 USA
I have recently acquired three home deep fryers, a Hamilton Beach, Rival, and T Fal, and all three reach a maximum of about 345 F when the thermostat is set to the maximum setting, which is 375 F. Does anyone know if I unscrew the heating element device, will I find something I can adjust? Or is there something I can do with the temperature dial? The photos are of the three deep fryers I have had.
Thanks,
George
I have a GE one that looks similar to #2 in your pics, and I don't see any way to calibrate it. I downloaded the manual once and don't recall anything about it either.
just a couple of thoughts...
1.You have three machines from different manufacturers with quite different looking thermostats.
They are all giving the same temperature when set to 375. I wonder if it is your thermometer that is wrong? maybe they are all giving 375 and your thermometer is under-reading? I have two milk thermometers for making espresso coffee. they do not agree, nowhere near it. I recently also bought an oven thermometer, I noticed in the stores that some of the cheap ones, there were several hanging on the display and they were showing different temperatures despite measuring the exact same temperature.
2.They probably all have a sensor probe for the thermostat. Check that it isn't touching the heating element, that will mean the probe is being heated directly by the heating element instead of purely measuring the oil temperature. (This would trick the thermostat into cutting off too early.) I used to cook for a living and for a few years we had a small two-pan benchtop commercial fryer. In that we had to check that the probe wasn't touching, it was held by stainless steel clips next to the element and could touch if it was sitting wrong - easily bumped during cleaning.
