Well, speaking of catastrophic failures...
OK, so I'm blowing it a wee bit out of proportion....
I spent the last week down in Ogden, hiding out with Canyon while they redo the floors and trim at the 'new' house in St-Liboire. I was eager to put the Norge into a permanent slot in the Ogden Laundry, so I double-checked and changed the clamp connecting the tub fill hose and the water valve on the '56 Norge. The good news is that the leak I had observed during the filming of the 'debut' was resolved.
The bad news was that the Norge no longer wanted to spin... I swear I could hear the Hotpoint mocking me from out in the garage.
So, I did some digging. The test I did was with a full tub of water. I noticed that when the washer started up in agitation, there was a short buzz from the motor but the washer would begin to agitate within 10 or 15 seconds. But when I tried to get '8 of 56' to spin, all I got was motor buzz... I siphoned out the water and tried again. The washer started to spin. As is the case with me, I was already jumping to conclusions about what was wrong. My first instinct was the belt tension. For the heck of it, I tried taking the belt off to see what the motor did. For spin and agitation, it started up immediately and seemed fine. I tried to tighten the belt, ever so slightly and with an empty tub, I was able to get the washer to agitate and spin. But when I filled the tub again - no dice.
I was a little miffed, but figured I should consult the doctrine... Fortunately I have the '57 Norge service literature from the board library. I read the symptoms and cures thoroughly - and sure enough, the manual had a section on the motor describing the trouble I had encountered. The suspected cause? A weak capacitor.
It made sense to me and had actually been one of my 'suspicions'... The start switch in the motor was another probable cause.
Well, I extracted the motor and took it to my faithful repair place in Magog last week to have both items checked. Hopefully I'll have a repaired motor sometime over the long weekend and the Norge will be set into its rightful place in the Ogden Laundry.
Of course, in the meantime, it's place is being kept ready by another, rarer machine of mine that miraculously fixed itself last week, no doubt as a consolation for not being able to play with the Norge. Hint: the washer brand name begins with 'D'....
