I've been very bad!
Believe it or not have found rinsing in a tub full of water using my "stomper" device rather effective rinsing. Know this because items placed into one of the German girls afterwards for rinsing gives clear water after the first spin.
Have two hand crank mangles which were fine for smaller items, but large bed and table linen wore one out. It is some trick to keep things evenly fed into the wringer while turning a crank handle. If things aren't spread evenly and or there are bunches the work becomes quite difficult.
My mothers system was wring into the rinse tub after washing, stsrt second load, wring backwards, so I had to catch the wash as a kid, then rinse and repeat the next load. Big stuff always gets jammed in the wringer. But it is still quicker than any new automatic today, That is except those of us that have real good vintage ones.
Saving grace of the Maytag wringer washers
Is their balloon rollers and self adjusting tension.
With hand cranked wringers even leaving the tension fully slacked still does not allow some thick items to go through easily if at all. Ditto for wringer washing machines where you set the roller tension.
According to my MT wringer service manual the only way to increase tension for the rollers is to swap out a few parts.
Ideally what one would love is to have a Maytag wringer for washing (that square tub Gyrofoam action) and a Bock type extractor or at least one with a bit wider opening, and larger capacity than typical domestic spin dryers. Such set would be like the Unimac UM 202
Hi Dear
Guess we should have told you about the pump! LOL
I'm sure you've got the hang of things by now, and have taken care of the bits of rust.
Have your had you maiden voyage with her yet?
Hi Stan!
No, no maiden wash just yet, need to get the old girl sorted first. Mustn't rush these sort of things. *LOL*
Yes, between the strong action of pump and the large/wide hose Maytag wringer washers seem to empty that 18 gallons of water rather quickly. Faster than any automatic it seems.
Ordered some Maycor center seal grease to lube the agitator spline and various points on the wringer as noted by the service manual. Also want to take the top of wringer off and before lubricating clean out the gunk and filth that has acclimated. Also am planning to lubricate the wringer shaft as well.
On another note finally got around to looking underneath and while all seems well (but then again don't really know anything from anything), there is a trace of oil along the center post down the left rear leg. This looks to be old and congealed so don't know if there was a leak at some point, and or perhaps the machine was laid down incorrectly at some point and oil leaked out.
Looked at the drain hose connection and it looks simple enough to replace if one wants something longer. As mentioned don't think there is room to move the machine close enough to the sink for draining. However do have an idea using the old "quick connect" hose saved from the Kenmore portable dishwasher before it was chucked.
Am thinking of connecting the drain end of that hose to the gooseneck with a hose clamp. If the connection can withstand the force of water out of pump would allow the machine to remain stationary in a wider open area for use. The other part of said quick-connect hose functions for filling so that is me sorted. At end of wash day can just undo the connection and that will be that. This saves having to accommodate a long drain hose when the Maytag is pushed into tight cubby for storage. Also am working under the IIABDFI (If It Ain't Broke Don't Fix It" theory. That is the drain hose is fine as it is now, but start messing with it and or the pump and who knows what could happen.
Will purchase one of the newer turquoise agitators with the "cup" to help keep water from getting at the seals.
Dear
Just A heads up.. when your ready to lubricate the wringer shaft..
I think your speaking of putting a film of oil on the metal pipe that comes out of the bottom of the wringer?
This requires the wringer control handle to be in the "swing" position. (Not neutral)
This also will require you to lift up the wringer assembly as show in your owners manual.
That assembly is very heavy. Please be careful.
Looks can be deceiving
While rooting about underneath to check about the motor, spied a bit of tape with writing stuck way up on the skirt. Was impossible to read while in place so managed to get a bit of it off.
Writing is faint because the masking type tape either came into contact with oil or maybe that is how it was back then. Near as can figure out it says something about machine being "returned" after a repair.
The rest is faint and difficult to read handwriting but the gist of things seems to be the old girl was once leaking gear oil and a "gasket" was replaced.
Haven't been able to get pictures yet, but there is a trail of oil along the housing for power bar (from motor to wringer) and down the left rear leg. It is all dried and gunky now, and so far haven't seen any traces of a fresh leak.
To be on the safe side am going to swap out the black agitator for one of the turquoise versions. Supposedly they offer better protection against water seeping down into the seals/gaskets. If the plastic spline makes too much of a "tick-tock" may seek out someone to swap it out for a metal.
Hi Dear
Thought I stop by and see how your doing with the new baby.
The oil that your speaking of is often times gear oil that has seeped out of the weep hole on the right angle drive. If you run you hand over the top over the right angle drive you feel a raised spot.. This is the weep hole. I'd clean things up and don't be concerned about it unless you find a puddle on the floor! Don't think you will.
Other than that, have you washed a load yet?
Hello Stan!
How sweet of you to inquire, people are so kind..
No, no maiden wash just yet. Have been busy with other things so haven't given much time to the Maytag.
Did gussie up the old girl by getting at the rollers. Couldn't get the pin on left side out so had to be contented with lifting the right so as to clean things out and put a touch of "center seal grease" on the bearings. Know some use oil but the repair manual said "grease" so that is what one used. Also applied a coat to the agitator shaft so as to prevent another stuck agitator event.
Other than that got out my can of vintage "Easy On" liquid glass and metal cleaner/wax (think Jubilee)and went to town. Did wash the old girl down with a bucket of hot water with a bit of dish soap and ammonia, which left a very nice shine. However wanted the protection of a wax to help keep any (more) rusting down.
My copy of Maytag wringer manual (blue cover) suggests waxing these machines about every year or so. Methinks as with a car the light coating of wax helps water bead up and protects the finish.
