junked a 2011 FPD Cabrio
cfz2882
Feb 9, 2010
2,688
Belle Fourche,SD
Got this machine about a year ago with freeze cracked inlet valve with intent to fix and when I had it hooked up outside for a test run,a hailstorm came through and bashed it up(did not break the thick glass lid)Washer ran good though drain pump was worn and noisy.Recirc pump ran good.Needed to clear space in shed,so this and a couple beat up ranges got junked-good parts salvaged from all,everything from the Cabrio was in good condition except the drain pump and inlet valve-cut out bottom of tub so BLDC F&P motor is ready to repurpose as motor or generator :) All of the hanging rod suspension was in good condition...good spare parts if another FPD Cabrio is obtained(a 10 VMW Cabrio is in collection)
