Just A General Wonder!
Thanks for sharing. Your washer looks like a feature-filled machine. Since you live across the pond, your machine operates on 230 volts, right? Is it cold fill only? How high is the maximum wash temp? I like those sensitive skin cycles. Do they give more rinses or higher water level rinses? Does your machine spin between every rinse? How many rinses does it give a cotton load? What is the top spin speed? We did not see Samsung front loaders until Maytag started selling a 6 kg washer and stack dryer made by Samsung between 2 & 3 years ago. The machines are not nearly as full featured as yours and the washer operates on 115 volts although the dryer is a 230 volt model. Thanks again for sharing your Samsung experiences.
Hiya, thanx for your reply!!:d the Samsung runs on a fully 240 volts, ur right , it is cold fill only. the maximum tepmperature is 95c, i find this machine increduble fleible beacause as with any cycle on the machine, you can select from 1-5 rinses it spins between every rinse on every cycle exept for Handwash, and the Woolens wash. the Sensitive Skin cyles have a more delicate type of agitation and high water level rinses no matter what the load size is, beacause with the rest of the programs, it determins the rinse level on The size of the load. the top speed of my machine is 1200. I think it is a brilliant washer however, it has a very sensitive out of balalance spin detector which can be a pain when washing small loads, but when big loads are washed, it will more or less spin unbalanced.
Hope this help!!:D
Richard
