scoots
A Maytag NX "Blue Bell" turned up on my local Craig's List. It had been up for some time and came down from $300 to $100. When I looked at it I discovered that the machine was almost pristine and worked perfectly so I bought it... and then made the mistake of putting it down the wrong way in my truck bed (wringer post DOWN)and a lot of the gear case oil leaked out.
I've done a search on this site, and apparently in order to get oil back into the case I have to open up the transmission. Is this correct? What specific type of oil is used? I know the wringer gear grease is still available, does Maytag still carry the transmission oil?
Are there any oil lubrication points in the roller head? What type of oil is used?
The agitator tends to float off the spline and I understand needs a rubber retaining ring. Does anybody know the specific part number so I can get the right one?
Last question is for a recommendation for a maintenance/service manual. The agitator has a manufacturing stamp for 1966, and I assume that it is original to the machine. Will any "N" series manual work for this model?
Thanks.
Thanks.
