leon88
Member
Hi, My KDI-18 Hobart Kitchenaid dishwasher suddenly stopped working yesterday. It's making all the normal sounds and the timer is moving through the cycles, but there is no water coming into the basin and the arms aren't turning. Based on previous posts here I am thinking that the inlet valve could be bad. If the pump was bad I guess it would be very quiet, right?
Is there any way to test this to see if the valve is faulty? It seems like an inexpensive part to replace and I found one on amazon for less than 20 dollars. Is this the right part number: wp4171000 ?
https://www.amazon.com/Whirlpool-WP4171000-Inlet/dp/B00ECV53BE
If the fill valve is bad, could I manually fill the washer with a bucket of hot water at the beginning of each cycle (prewash/wash/rinse) to get the dirty dishes loaded in there cleaned?
