KDS-16 Timer needed
marksman
Member
Feb 22, 2011
16
The timer on my machine keeps stopping. I keep the front bottom cover off and can restart it with a tap of a screwdriver on the motor puck.
Are these serviceable? Can I take it out and clean it with something?
Are they available? Does anyone have a part number or even better,
does anyone have a spare for sale?
Thanks
Rick
Thanks.
A quick search shows that that timer is not very easy to come by.
Most of the timers seem to have the same timer motor.
Does anyone know if there is a generic timer motor that can be fitted into this timer?
Thanks again
Rick
KDS-16 TIMER
Is it just the timer motor you need and which timer motor there two one regular speed and the rapid advance motor. There are also two different KDS-16s the later machine has the soak cycle instead of the heavy wash cycle and they have different timers. Let me know I may have good used parts you also may be able to send the complete timer to Mid-West timer for repair.
First, next to the "Full Cycle" button is "Heavy Soil" button. So I assume I have the earlier model?
Inside the front/bottom cover, facing out, is a 2 inch diameter by 3/4 thick timer motor that says Schiller Controls on it. It is a bit rusty on one side.
The dishwasher occasionally wouldn't start. A slight tap on that motor starts the machine. I think it is getting worse. The washer has stopped at times while running. Again, a slight tap gets it going.
Does that sound like the rapid advance or regular timer motor?
Thanks
