quick-connect
Member
- Joined
- Jul 14, 2007
- Messages
- 18
I recently bought thing while my wife was out of town thinking I'd install before she got home. Six months later I hooked it up outside to the garden hose and power to test it.
I hooked the water hose up to the intake valve (I don't know what else to call the valve with solenoids attached which connects to the water source). The metal plate that the intake valve is attached to is very corroded and there is a pinhole leak which shoots a teeny-weenie stream of water at the nearby drain solenoid. I applied a paliative piece of duct tape to protect the machine from this leak, and the full cycle continued without event.
After prewash commenced, I opened the compartment, and felt the water in the basin. It was cold. Later I realized the "energy saver" was probably on. It seems like it's a button, but it's not easy to push, or rather, it is hard to tell whether it has been pushed when you use pliers to impress the button fork. In any event, if it is a button, it's missing. The only other think it could be is a slider switch, perhaps.
The drier fired right up at the end, promtly drying the inside of the washer with hot air.
Where can I get a new intake assembly?
Where can I get a new energy saver button (or it is a slider)?
How common is it for the water heater on these things to die and how hard is it to replace? (not that it's dead, but with the energy saver mix-up, and the fact that I will not be able to test it, it would be good to know)?
I did not measure the water usage, but it would be good to know.
PS, I posted here in 2007 when I was given a perfect kds60A, and I never forgot the help I got. I lost the KDS60A in a breakup. Here's that thread for a fun read and some pictures of a fine kds60A specimen. http://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?12793
