Clock repair
Gary,
Thanks for the welcome. As I understand it, the most common clock problem on these ranges is the "Telechron rotor". My clock had begun to make noise and run slowly, so I bought a used rotor on eBay and put it in my clock. It ran fine for 5-7 years, and then began to display similar symptoms (noise & slowness).
Somewhere, I read that these rotors can often be "fixed" by SLOWLY adding 3-in-1 oil through the hole under the external gear. I had done this to my original rotor after I removed it. So, when the replacement rotor began to act up, I put the original rotor back in, and it has run fine for several years now. I've since oiled the replacement rotor, so it's ready as a backup if I need it.
If you order a replacement rotor, you want to be sure it matches the one in your clock. Fortunately, there are codes stamped on the side of the rotor that make this matching relatively easy to do.
If you'd rather not mess with all this, there are companies that will fix your clock if you send it to them. Sandy posted the name of one such company earlier in this thread. Good luck!
Dean
Gary,
Dean
