The upper two seals (now just one seal?) had the seal lips "up" as the machine sits.
Which direction does the lower or bottom seal point it's lips?
I was assuming all the seals on the post seal water from upstream, to keep water out of the clutch drum?
So do all seals on the center post point lips "up" ? The only instructions I can get, plus the parts diagram, are so blurry I can't tell.
Thank you, Paul
Thank you, Paul
