dartman
OK, I have been fighting with this thing since we got it about 2014. Some of you may remember my battles after the first set of bearings went out after it was about 4 years old.
I bought a cheap Chinese kit with everything including the bearing installation tools. It was junk and lasted a month but the tool is fine, got a whirlpool OEM kit and it installed fine and didn't leak or anything and was done after a little over a year.
The last set was a Chinese set but had a lifetime warranty which they appear to be willing to honor but the machine now is also throwing a UL unbalance code and the bolt underneath still seemed tight when I checked it again.
I don't want to throw another shaft/seal/bearing set in it again then have to chase a balance issue on top of things.
I don't want a old school Speed Queen because our water rates are super high. Has Whirlpool fixed the issues they were having with the seals and bearings like the machines from my washers time were having or does somebody else now make a reliable HE top loading machine that will last and can be self serviced reasonably like the Whirlpool based machines used to be.
Thanks for any suggestions guys, getting pretty frustrated here. I don't mind replacing parts as they slowly wear out but doing this almost every year is getting real old.
